Changed ink cartridges in c5180 HP all-in-one Photosmart and now I get error oxc 18a0001 when i turn it on. Tried your suggestions but problem persist. I put Premium Remanufactured cartridges. Thank you for your help.
THAT 0X ERROR IS AN INK SYTEM FAILURE IT MAY HAVE BEEN CAUSED FROM THE REFURBED CARTRIDGES... THE HP WILL WORK WITH THE REFURBS FOR A FEW TIMES BEFORE REJECTING THE CARTRIDGE OR CAUSING AN 0x ERROR. THE UNIT NEEDS TO GO THRU AN ELABORATE INK SYSTEM RESET. OR HAVE THE PRINTER REPLACED
To bypass
INK SYSTEM FAILURE messages please see the HP Printer Diagnostics Tests file
(pdf) for instructions: http://inkjet411.com/?page_id=1813
Verify the
permanent built-in PRINTHEADs electrical performance inside this legacy printer
model by running the TAP 43 diagnostic test (either one of the procedures below
applies to all printers which use HP02 or HP363 ink cartridges): For additional HP02 support information, please
visit our HP02 system support page which includes videos of everything
mentioned below: http://inkjet411.com/?page_id=1372
A. HP02
ink-series printers with KEYPAD (i.e. keypad numbers 1-9)
Tap
43 PRINTHEAD Health Diagnostics:
Video Procedure: http://inkjet411.com/?page_id=2391
1.
Press * and # keys simultaneously.
2.
"Enter
Special Key Combo" will be displayed.
3.
Press 123 to display the 'Support/Service' menu.
4.
At 'Support/Service' menu, click the Right Arrow
3 times until Special Reports menu is displayed.
5.
Select Ok, then click Right Arrow 2 times until the
'print-mech button tap' menu is displayed.
6.
Select Ok ('code = 0' will be displayed); click
and hold Right Arrow until 'code = 43' is displayed. Use the Left Arrow if you
need to decrease numerical count.
7.
Select Ok. The test page prints.
8.
Check the 4th line at the top of the printed
report; an electrically good/stable PRINTHEAD 'Pen Status' will state "Pen
Status: Pen OK".........if any other message
is displayed then the PRINTHEAD may have failed and may need to be replaced (if
part is still available). It is suggested to perform the 'Printer Reset'
procedure below to first rule out printer firmware related problem.
B. HP02
ink-series printer models that DO NOT HAVE a KEYPAD:
Internal Test Print:
1. Press the Menu button, press
the Right Arrow button to select 'Tools', and then press 'OK'.
2. Press the Right Arrow button
several times to select 'Print Test Page', and then press 'OK'. The test page
prints.
Tap 43 PRINTHEAD Health Diagnostics -
See Video Procedure: http://inkjet411.com/?page_id=2377
1. Turn
ON the printer.
2. Press
and Hold the "Print Photos" & "Red Eye Removal" buttons.
3. Release
both buttons.
4. You
will see a new screen that says, "Enter Special Key Combo"... The Key combo is:
press and release in sequence the "Red Eye Removal", "Print Photos", and then
"Red Eye Removal"
5. Scroll
through the menu by pressing the right arrow button until the display says
'Special Reports'.
6. Select
Ok, then press the arrow button until the 'print-mech button tap' menu is
displayed.
7. Select
Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 43'
is displayed.
8. Select
9. Check
the 4th line at the top of the printed report; an electrically good/stable
PRINTHEAD 'Pen Status' will state "Pen Status: Pen OK".........if any other message is
displayed then the PRINTHEAD may have failed (unfortunately the PRINTHEAD is
not replaceable). It is suggested to perform the 'Printer Reset' procedure
For additional and advanced HP printer diagnostics,
please visit: http://inkjet411.com/?page_id=1813
To help solve other HP02 ink-series printer/printing
related issues please visit http://www.inkjet411.com
