When I turn on my nokia 3230 phone, the screen appear only in white, nothing else.
You need to format or hard reset your phone. Hold the * + 3 + green call key and then start up your phone while holding those buttons until you see a screen that shows formatting. Make sure you have enough battery power to do this procedure. You can plug the phone charger to make sure that everything will be OK.
Try this, it might work for you. First remove any extra memory card and sim card inside your phone. After doing that, turn on your phone without those things. If there is message "Please insert sim card" then your good to go. Put your sim card back to your phone and then turn it on again. If it is successfully start then next thing to do is to insert the memory card back to your phone and then start up your phone again. But if in this stage your phone failed to start, then the memory card it causing the problem.
If all fails, then you need to format or hard reset your phone. Hold the * + 3 + green call key and then start up your phone while holding those buttons until you see a screen that shows formatting. Make sure you have enough battery power to do this procedure. You can plug the phone charger to make sure that everything will be okay.
Please leave comments for further instructions. Thanks..
