I have a AWA 747 dvd player which i solely use for the USB port to watch programs but my son has managed to misplace the remote!!! can you recommend a replacement remote that will be able to access the USB on the system? or know of retailer that sells replacement remotes
1. make sure there is no disk in the player 2. plug in the usb device 3. wait (about 10 seconds) until the player detects it and comes up with the file list 4. press play button on the player 5. when the first file is loaded press "next" to go to whatever you want to watch.
hii, It seems your video has been corrupted, so you need to have repair software, which can regenerate the desired file. If you are unable to find such software you can ask me.
I don't have other code for your DVD but I can give you the steps on how to program your remote to your DVD without the list of codes.
1. Turn on your DVD. 2. Press the DVD Mode Key. 3. Hold down SET on the URC for 2 seconds until the indicator lights up. 4. Enter 0005. The indicator should go out immediately. 5. Press the DVD Mode Key again as in step 2. 6. Hold down SET for 2 seconds until the indicator lights up and your URC is ready to start searching. 7. Aim the URC at your DVD, press the power key repeatedly, slowly until the DVD has been turned off. Once your DVD has been turned off, immediately press SET to lock in code and the indicator should go out.
Go to http://remotefinder.rca.com/default.aspx?site=RCA follow instructions choose remote type you have then type of device u want 2 program remote for and then choose brand of that device and try the codes; simple
put the code into the remote that relates to the brand (AWA) AWA is not a major brand and may be hard to find any code that works in it. I found 2 here that you can try 0753 or 0895 If either work, write them down on the DVD player do you can remember them next time
I see that you also own a esc dvd-690 player. I have one too. Unfortunately I have misplaced my manual, and I need to know how to use the USB port on the player. I tried sticking in my thumb drive, but it wouldn't read it. Do you know if theres something special about the USB, that you need to know before using it?
