Question about Sharp AR-5316 Advanced Digital Imager Copier
Error f2 in sharp copier AR5316E
I want remove F2 in my copier
  • Anonymous Mar 29, 2010
    I want to removr F2 in my copier AR5316E
Anonymous
    New Friend:
  • 74 Answers
F2 sub code 00 - Toner Sensor problem, ID pattern reading error. You may have to replace the drum unit or have a tech clean the toner sensor
Posted on Mar 31, 2010
Anonymous
  • 5 Answers
Replace toner cartridge.
Posted on May 23, 2010
What is the solution of sharp showing f2-40
toner problem, remove toner restart copier and reinstall toner. If that doesn't work you may need a new toner.
Jul 08, 2014 | Sharp AR-M237 Copier
Code f2-65
Cyan toner problem. It could be defective toner remove it turn copier off and back on and reinstall toner. If that doesn't work try a new toner. Beyond that you will need a Sharp trained technician.
Jul 07, 2014 | Sharp MX-2700N Color Copier
How to remove code f2 from a Sharp AR-5316
What is the next after f2- or if f2-64 check development un or connect the connector chip.Replace development unit.
Jun 10, 2014 | Sharp AR-5316 Advanced Digital Imager...
After installation my sharp ar-m420u copier mx-2300g displays error codes L1-00 and F2-00
L1 MEANS U HAVE TO REMOVE THE SCANNER LOCK WHICH IS ON THE SIDE OF THE MACHINE.
F2 MEANS SOME PROBLEM WITH YR TONER CATRIDGE.CHANFE IT AND SEE
Jan 11, 2011 | Sharp AR-5320 Black and White Copier
Problem with the Sharp -COPIERS - AR165 Call servis F2-04
Hi, this is a problem to do with the toner cartridge.
Answer
  • Try to remove it out and re-insert it.
  • Replace the compatible toner sensor with the old one.
  • Please use Ar 202ft original toner cartridge which fits this machine.
  • Your problem is now solved good times.
Nov 22, 2010 | Sharp AR-5316 Advanced Digital Imager...
Our Sharp mx-3501n copier flashing improper cartridge code: f2-70 and will neither copy nor print. If we restart the code still remains never go out, Do you know what is the problem? Thanks. my...
Your copier is not accepting your black toner cartridge (F2-71 Cyan, F2-72 Magenta, F2-73 Yellow). It either is not inserted properly, the packing tab is not removed from the back, or a faulty cartridge. Often 3rd party cartridges that the manunfacturer "guarantees" will work will bring this code. In short, the copier is rejecting your black toner cartridge and you should replace it.
Oct 25, 2010 | Sharp MX-3501N All-In-One Printer
A copier model sf 2220 shows F2 pls what can i do to that?
hello,
you have not installed the developer (it's a steel-colored envelope that must be purchased separately if not included in installation). To do this you need to remove the toner cartridge that you entered, and remove the screw with a screwdriver blue. slip off the drive containing the hopper and fill the whole bag well distributed along the developer hopper. Reinsert done this, tighten the screw and install the toner and error F2-40 is resolved. if you need instructions let me know. Hello Valerio
Jul 14, 2010 | Sharp AR-5316 Advanced Digital Imager...
MY AR 5320 IS SHOEING F2
it must have a sub code, F2 sub 40 means you have a wrong toner cartridge, sometimes F2 is caused by lose or broken harness in scanning section, in this case it sometimes display an E7 code.
Jun 24, 2009 | OCE 3140 Copier
My 5316 copier keeps blinking F2 and willnot print I have changed my developer still it keeps showing F2
F2 - Black toner supply trouble
Try a different toner cart, remember to shake the cart. before installing. Power the machine on and off and check. Check the sealing tape has been fully removed from the cartridge as well as the green colored plug.
Also, if you have an original drum unit frame, change the frame with the new Modified version to prevent arching at the rear cover of the drum unit against the inside back plate of the machine.
Check that the black dev. tank is not low or empty, re-position both drum & dev. tank.
Pls rate - Thank you
Mar 02, 2009 | Sharp AR-5316 Advanced Digital Imager...
F2 error
"F2-31" Image density sensor fault "F2-32" Drum mark sensor fault "F2-33" Grid voltage correction problem "F2-35" Grid voltage correction problem "F2-37" Drum mark sensor fault
Sep 03, 2008 | Sharp Office Equipment & Supplies
Sharp AR-5316 Advanced Digital Imager Copier Logo
778 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
