If the fan is working o/k, then it is going to be a faulty oven element, fitting a new one should solve the problem.
Posted on Mar 29, 2010
Testimonial: "Thank you very much i will get a new element fitted."
Candy Oven not heating? How to replace a Candy fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
You searched for candy element How to Repair Home Appliances
Posted on Jan 30, 2014
SOURCE: Candy F254/3X single fan oven, grill works, oven doesn't.
If fan is working o/k, then you need to fit a new oven element
Please`rate my solution.
Thanks.
Posted on Aug 24, 2009
Testimonial: "Possibly looking for a bit more info. My manual talks about top and bottom elements. I take it the grill is the top element."
SOURCE: oven not heating up
You need to replace the oven element, as it has probably blown.
It is located at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Posted on Jan 18, 2010
Testimonial: "Thanks for your help, I haven't sorted it yet but is given me a place to start. "
SOURCE: CANDY OVEN
It will be the oven element that has failed, you need to fit a new one.
It is located at the rear of the oven compartment.
Posted on Feb 22, 2010
Testimonial: "GR8 JOB HAVE ALREADY SEARCHED ON THE NET BUT THIS CONFIRMS. NICE ONE CHEERS."
SOURCE: my candy oven r43/3xuk wont switch on. The power
If the fan is working o/k then it is likely to be a faulty oven element if it is a
electrically heated oven.
If it were the timer, not even the fan would work.
Testimonial: "Thanks looks like it'll cost a fortune!!"
SOURCE: volume control candy oven timer
Switch off the oven, leave for 5 seconds and switch it back on.
Candy Customer Services asked for over £100 to have an engineer sent to my house, which I refuse as I thought the oiven was good.
I had to switch off all the electricity in the kitchen but after this 'reset' the oven turned to the normal 'high' volume.
Posted on Aug 03, 2010
