Hello ,
This is due to your computer software selecting the manual feed instead of tray one usually because the software program decides that the paper size is not the standard letter size, such as envelopes, and has to go through the manual feed.
If you are having trouble finding the manual feed, it is found just above the paper tray, usually on the front panel of the printer.
If you are trying to print a letter sized document yet the printer still asks for the paper to be inserted into the manual feed, then one of the settings in the software you are using needs to be changed.
For most windows based applications, you can find a “page setup” menu; in this menu, there is a section that specifies the tray being used to print from.
Make sure the setting in page setup is set to “tray 1” and not “manual”
Thank you,
