Question about Elna Heirloom Edition 6005
Machine Elna Supermatic 722010 When I sew with a single cam all works properly the problem comes with any twin cam, the upper cam follower has a spring holding it away from the cam, how do I get the upper cam follower to engage the upper cam. The machine is perfect with a single cam or straight stitch just the twin cams are the problem. Any one have a macro shot of the inside of the cam cover with a twin cam installed and the upper cam follower in contact with the cam.
  • 1 more comment
  • Tally Girl
    Tally Girl Mar 03, 2011
    Have you resolved this issue, I have a Supermatic at home so might be able to assist you?
  • Anonymous Mar 03, 2011
    No I've not found the problem yet I need a closeup picture of the twin cam with the upper and lower cam followers engaged to get the twin cam stitch pattern.
  • Tally Girl
    I've just shot some pics of mine, can you email me on [email protected] and I'll send them directly to you? Embedding them into this page they won't be clear enough.
Tally Girl
  • Elna Master
  • 1,134 Answers
Machine Elna Supermatic 722010 - tally_girl_2.jpg I don't suppose it would be so simple as setting the wheel inside the elnagraph to "A" to engage the automatic stitches? I've done it myself once or twice LOL.
Posted on Mar 03, 2011
Where to get a user manual for Elna Supermatic 722010 sewing machine - vintage 1963-1964
Hi Beverly,
My suggestion is that you join up the Yahoo group called "Elna Heirlooms" you'll find lots of very helpful fellow supermatic owners there and probably what you are looking for too. Here is one page from the manual for threading the bobbin into tension, once you've mastered this on the Elnas, its the same for all the Swiss ones.
Yes, top threading is important, you need to get the thread into the tension discs and also the take up lever. Have you cleaned out the tension discs too? these do get gummed up with fibres and dye particles sometimes. Just turn tension down to zero and "floss" between discs with the selvage edge of a clean piece of waste cotton fabric.
Might see you over on Yahoo, several of the members there are really knowledgeable on these great machines.
cheers
Tallygirl
Oct 13, 2011 | Elna 2007 Mechanical Sewing Machine
Do I need the model no. to order a manuel. For the Elnasuper is this a model no. 7131 ?
The Swiss Elnas included several models called "Supermatic" and SU so it is good to identify your machine by the model number.
If you look at the Identification plate on the machine it should have a 2 digit model code and a serial number.
However, one of the very early machines was called a 722010.
If you browse www.whitesewingcenter.com you may find your manual available there. He is the Swiss Elna guru for old parts and accessories.
Aug 22, 2011 | Elna Sewing Machines
On my elna supermatic 722010 sewing machine, the thread makes the bobbin pop out and the thread get tangled underneath. I have had it fixed twice, which is expensive. Should I just get rid of it and buy...
not unless you can find another swiss elna, like star series su. check bobbin in right way, holes on top to wind and load. you havent bought anothet type bobbin??? go to www.arizonaexpressionz.com and download a manual for supermatic. then read bobbin winding and threading carefully and rewinf bobbin and thread up again. make sure thread goes into tension spring all the way. bobbin should turn anticlockwise when yoou pull thread. also please brush clean bobbin holder area and check for any threads caught there. now a drop of quality clear machine oil in middle hole and gently run for 30secs to work in. do this every time you get your machine out. there are several oiling points shown in manual. oil them. these machines are quality but yours may need love tlc from a elna tech especially if it has not been serviced in a while. but a well maintained elna will out stitch a new plastic machine any day in my humble opinion. if you want to join yahoo group elna heirlooms, experts who service their own and share photos info manuals and love these vintage classics.
Jun 16, 2011 | Elna Sewing Machines
I HAVE A ELNA SEWING MACHINE MANUAL AND CAMS AND FOOTS TO FIT OF ELNA SEWING MACHINE BOUGHT 52 YEARS AGO UNFORTUNATLEY I DO NOT HAVE THE SEWING MACHINE I LEFT THAT WITH A REPAIRER HERE IN ADELAIDE AS IT...
I would love to take these off your hands as my Mum has an Elna Supermatic that was her mum's. Could you email me on [email protected], I'd be happy to pay postage to ship, I'm up on the Gold Coast.
thanks
Carolyn
Mar 17, 2011 | Elna Sewing Machines
What bobbin size for elna supermatic 722010 Can I purchase metal bobbins for this machine at a Joannes? or ? Is there a staner bobbin number or size to ask for?? [email protected] The Elna I have came with ONE...
Elna Supermatic 722010 is a very vintage elna and would take the metal 7 hole dished bobbin like this.
Don't try to use any other bobbin in it, and always load and wind with the holes on top.
You can still buy these; one supplier is sewingpartsonline, here is like to the item
http://www.sewingpartsonline.com/bobbins-elna-426000-10pk.aspx
Aug 17, 2009 | Elna Heirloom Edition 6005
Extra discs for an vintage Elna Supermatic plus pressor feet.
Try the usual eBay route, but also approach any Sewing Repair shop as they often acquire odd bits from old machines....We had 9 disks for a lady with an Elna SU only last week, all from a machine traded 2 years ago and really beyond resale.
Aug 02, 2009 | Sewing Machines
Have a 1970's elna su supermatic but cams don't work
There are two types of discs - single and double.
For the thinner single discs do as follows:
1.Turn stitch width knob to "0"
2. Turn stitch length knob to "0"
3. Insert the single disc
4. Turn the top selector to "A"
5. Make sure the needle selector is in the centered position.
6. You may now choose any stitch length or width you wish. I usually try "3" for the width and 1/2 for the length to start.
For the thicker double discs do as follows:
3. Insert the double disc
6. You may now choose any stitch width.
7. The stitch length must be put on "A" - this is the difference between the single and double discs!
I hope this helps!
Mar 11, 2009 | Elna 1010
Sewing Machines Logo
610 people viewed this question
Top Elna Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Nick Olsen
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
