Question about Stanley Composite Hacksaw
I have a Stanley hacksaw 15-892 12" composite and I bought new blades to change them but I can't seem to figure out how to install new blades. I don't believe misplaced any parts as far as I can tell.
Posted by t_dog_g on
Stan Ford
    Genius:
  • 2,910 Answers
Easy-open lever for quick blade change.
Posted on Jan 29, 2015
2 Related Answers
ADRIAN
  • 313 Answers
SOURCE: How do you load a new blade?
At the back end of the knive (the curved end) press the black piece through the yellow rounded part and the yellow front and the black back will part, now slide the yellow part back to reviel the blade folder. Fit new blade then refit the yellow part on top of the black part and slide the yellow part foward to lock it back in.
Posted on Jul 31, 2010
lstimo
  • 27 Answers
SOURCE: I cannot figure out how to put a blade in my
at the handel end it will pull apartthen slide the whats left of the old blade and put new won in its place just do it slowly so you dont forget how it goes
Posted on Apr 21, 2011
I bought a new balde for hax saw and somehow i get the new balde inn, everytime i tried to tightenning it always lose.
it there is not enough adjustment left to tighten the blade the frame is bent or you have the wrong blade.
Sep 24, 2011 | Stanley Composite Hacksaw
I cannot figure out how to put a blade in my Stanley FatMax fixed blade utility knife. There are no instructions with the knife.
Apr 21, 2011 | Stanley Utility Knife
How do you put blades in stanley fat max extreme razor knife
Not sure exactly because I don't own one, but the review seems to indicate you push the blade positioner all the way forward, and push a release to remove the old one out the front, and then push a new own in until it clicks in place. With the blade positioner all the way forward.
But the review said it did not work well.
http://www.crunchgear.com/2008/12/05/review-stanley-fatmax-utility-knives/
Feb 26, 2011 | Stanley Garden
How do i change the blade on the stanley 20-115 hacksaw?
The 20-115 uses a quick release lever at the front of the saw. Opening the level by hand with a forward motion will unlock the blade tension allowing you to replace the blade. Pull the level closed to restore tension to the new blade.
Oct 28, 2010 | Stanley Hand Tools
WAS ABLE TO OPEN THE STANLEY SWIVEL LOCK UTILITY KNIFE AND REMOVE DULL BLADE. NOW i CAN'T GET THE NEW BLADE IN AND CLOSE THE KNIFE PROPERLY, WHAT'S THE TRICK?
If you use the wrong brand of blades, they won't let the knife shut all the way. The notch is cut slightly differently. The same is true for the Kobalt knife I just bought at Lowes. Get the Stanley blades that are right next to the knives - they are the only ones that work.
Sorry.
If you bought the Stanley blades, then I don't know what the problem is. Sorry for that too.
Nov 20, 2009 | Stanley Swivel - Lock Fixed - Blade...
SPARK GAP FOR 1990 TOYOTA COROLLA I bought NGK G-POWER PLATINUM SPARK PLUGS Looking everywhere - I checked all the panels under the hood and I don't have a car manual for my 1990 4 cyl 1.6 litre 4-door...
Do you happen to have a hacksaw blade? The thickness of the hacksaw blade is equal to the clearance of the
spark plug contacts. You can put the hacksaw blade flat
between the contacts, and make the necessary adjustment. Then, start your engine. Send in your e-mail
so we will know.
Oct 11, 2009 | Toyota Corolla Cars & Trucks
Bought a junior hacksaw which the blade comes upside down in. Tried twisting the frame to get the blade out but can't. Any ideas please?
To remove the blade from the junior hacksaw, hold the handle and push the other end against something (like the floor) to carefully bend the frame and un-clip the blade.
Sep 02, 2009 | Hand Tools
STANLEY QUICK POINT BLADES...CAN'T FIGURE OUT HOW TO CHANGE.
There is a SLOT in the end of the knife. Simply insert the strip of new blages in to the slot and you are ready to go.
Good luck. :)
Apr 25, 2009 | Stanley Hand Tools
Stanley Composite Hacksaw Logo
1,268 people viewed this question
Top Stanley Saws Experts
Rob Bridges
Level 1 Expert
efs_perpends
efs_perpends
Are you a Stanley Saw Expert? Answer questions, earn points and help others
