Question about Sony RDR-GX7 DVD Recorder
DVD hooked up to sony bravia tv: have dvd power on, but can not get any set up menus (or anything) from dvd to show on tv screen.Unable to set up remote as menu does not appear on tv screen.
  • Anonymous Mar 29, 2010
    Everything appears to be connected correctly (with RGB). Although the Monster cables look good, I am suspecting a problem with them. Remote works, but no image of any kind appears on TV.
  • Anonymous Mar 25, 2014
    menu button on my dvd remote does not give options
John Street
    Guru:
  • 513 Answers
Hook up the player with RGB (Red-Green-Blue or component) cables and try the picture. If everything works OK, then go to the menu and turn on the HDMI output and set the resolution (if needed).
Not every HDMI unit works with every HDMI TV. You may also have a bad HDMI cable. On a DVD recorder, you may have your HDMI cable connected to HDMI IN. You must use HDMI out.
Posted on Mar 29, 2010
Testimonial: "Great idea! I will try it. I did turn on progressive, but I think trying the regular video 1st to get menu is brilliant. Thanks!"
  • John Street
    John Street Mar 30, 2010
    Some DVD s do not put out any signal on RGB until you switch to Progressive. If your remote has a progressive button, try it.
    You will have to hook up with regular video first to get the menu if that does not work. Use the menu in regular video, turn on progressive and then switch to RGB. Its a pain, but it may work. Depends on the DVD player.
Sony Bravia TV
If you get a blue screen at turn on and a short time later it shuts off--power supply is ok--set is shutting down as no signal detected to protect the screen.
If using a box first unplug it and wait and plug back--let box try to reboot itself.
Also as a test hook a DVD etc to a rear set of audio/video inputs and go to that input quickly when the set comes on (have DVD connected and on---see if set works that way.
No signal either a problem with the set or the signal source (box?).
Mar 31, 2012 | Televison & Video
I purchased a 46" Sony Bravia flat screen TV. I
Try going into menu input set up on tv and switch to av input. Just a thought I have the same model and had exact problem. All I had to do was change input style to av cable.
Jan 25, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
My BRAVIA KDL-46XBR3 shows like a mirror image below whatever is being shown
many bad lcd panels will show issues like this
check the menus and if theyre bad its likely a bad lcd panel
i'd complain to sony and see if they are extending the warranty for this issue as some xbr panels were defective
May 22, 2010 | Sony BRAVIA KDL-46XBR3 46 in. LCD HDTV
We have a Sony Bravia and we cannot figure out how
check your connections first, dont use these connections with many pins, make sure use of those coaxial cable connections. if you dont have an indication on tv. check your cable for cuttings between main conductor and outer screen. using a avo meter.
Jan 11, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony bravia-unable to tune in video channel via dvd
thethe wires have to run out of your cable box into the dvd recorder then back out to the tv,try rehooking it up
May 19, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Onkyo HT-S6100 to OPPO Dv 980H to Sony Bravia KDL 40W4100
Make sure none of the Digital or Component Input Assignments are programmed, if you're not using them. Set them to "----". This may help. Some of the Component input assignments may over-ride your other input assignments (perhaps even the HDMI input assignments).
Jan 25, 2009 | Onkyo DV-S353 DVD Player
I can't seem to get my dvd player to play on screen
Set the TV to look for a signal on the same input your are hooking your dvd player to. Example, if your dvd is hooked to video 1, set the TV to show video 1 on the screen.
Dec 31, 2008 | Dell Televison & Video
DVD is wired to the VCR and does not work
The Sony Bravia should have a number of component inputs, so you should be able to hook up the DVD directly to the TV. The only reason for hooking it up through the VCR would be to record a DVD on VHS... but that's for the birds--VHS is old technology.
Each component input on the back of the TV has a number. You then select to view the component you want by pressing the remote control button to change the display (it should show with one you're on... e.g., Video 1, Video 2, Video 3, etc.).
Dec 24, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Stuck in progressive scan mode.
Based on your description, it seems that you set the DVD to progressive scan output, but have it hooked up to a TV (CRT) that cannot accept this signal. Because the TV can't accept the signal, you can't view the DVD menu to change the setting back to interlaced.
On the back panel you have "Component Video Out" for output via component cables, but there is also a yellow RCA connection labeled "Video Out". This is a "composite video" connection which does not support progressive scan. Try disconnecting the component cables and connect the composite video to a TV. The DVD will likely (hopefully) send a compatible signal (480i) through this connection, which will give you access to the menu.
May 12, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Can't remove AV Input display
Try setting hdmi control to off in tv menu
Apr 06, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony RDR-GX7 DVD Recorder Logo
295 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
