My Sony Handycam DCR-HC42 Mini DV digital recorder is not recognized by Windows 7 Home Premium 64-bit when connected via USB. This worked fine on XP Pro with my prior PC. Sony support download site says the driver is included with Windows 7 and does not offer a download. I have installed the Sony PMB application, but it cannot locate the handcam. Searched the web for another provider of the driver without luck (including Driver Whiz application). Any help would be appreciated. Thanks.
Win vista and win 7doesn't support usb streaming. the usb driver for this model would not be compatible with your computer's OS. although, you were able to download PMB still this wouldn't work, it's basically an alternative software that you can use with the newer OS. still the device driver would not be installed. and you would get a message that "ilink connection is not detected". the reason you get that is bec the camcorder and the software is intended for use with the dv (ilink or ieee1394) connection. so if your computer has an ieee1394 card and you have a compatible ilink cable,then your good to go,it should be a plug-and-play connection (no drivers required). all you need then would be a video capturing software (like win moviemaker) to transfer videos from tape to PC. hope this helps. thanks :)
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Maybe, It doesn't work because the driver you installed. It is for other versions of operating system. I am also using windows 7 like you.Dont worry, You can still use your installer/driver from other versions of operating systems. Before you installing any program/driver in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer first, then choose "troubleshoot compatiblity". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D
