Panasonic Panafax UF-790 Plain Paper Laser Fax Logo
Posted on Mar 28, 2010
Cannot install machine - Panasonic Panafax UF-790 Plain Paper Laser Fax
I have a Pfaff 300e Smart Machine....tried to use it on Windows 7 and Windows 10 and it tells me the machine is not connected to the computer...cannot figure out the problem... JuDee
Navigator Software
The Navigator software is launched whenever your machine is connected to the computer and the machine is on. This software communicates with the machine.
If this is not installed follow these steps;
  1. make sure the machine is not connected to the computer.
  2. start the install sowftware,
  3. The install will then ask for the machine to be pluged in and turned on.
  4. After the install is finished, restart the computer.
Link to manual is below;
http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/Smart_300E-manual-EN.pdf
Software link below;
http://www.pfaff.com/en-US/Support-and-Updates/Complimentary-Software
If this was helpful please click the helpful button.
Having trouble picking up bobbin with needle.
Install a brand new needle--verify it is installed correctly. (Usually there is a flat part of the needle that must face a specific direction when installed in the machine. Installed incorrectly, it will never sew.)
If a new needle doesn't work, most likely the machine is out of time. Search for sewing machine timing or take it for service.
I put a new hard drive in my machine, and cannot access internet because it says this machine doesn't have any installed network adapters. How do I install?
Hello, presumably you've reinstalled Windows after fitting your new drive. Well, you have to find all the drivers for your machine including the chipset drivers (importantly you must install these 1st)) then your system will 'see' the adapter. If you don't have your driver cd's, then you must go to the web site of Acer (obviously from a machine that can access the internet!) and download all the relevant drivers to a memory stick or burn 'em to a cd, then install them onto your own system. Regards,nicam49
How to install a lock cutter on singer 8280 sewing machine?
How do i install and use my lock cutter on my singer 8280?
2answers
COMPUTER CRASHED I NEED TO RELOAD CD BUT I DONT HAVE ACCESS CODE
There are now several versions of the basic Futura software and AutoPunch available on the market. The most current is version 1.0.0.2. To determine what version of either software you have, you will find this information around the inside rim of the CD at approximately 4 o'clock. Before loading any of the Options into your computer, check the version and then follow the steps below. The following steps will update your software so that you will now have the latest 1.0.0.2 version of the basic program and all options.
To load base software 1.0.0.0 with AutoPunch 1.0.0.0 or base software 1.0.0.1 with Autopunch 1.0.0.1
  • You must use bobbin part number 085128. This bobbin is specifically designed for the Futura CE-100 and CE-200.
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Turn on Futura machine and double left click on Futura icon to open program
  • Close program and turn off the machine
  • Install Autopunch and leave the CD in the tray
  • Download appropriate update for Windows Version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop download icon to install update
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program
To load base software 1.0.0.0 with AutoPunch 1.0.0.1 or base software 1.0.0.1 with Autopunch 1.0.0.0
To load base software 1.0.0.0 or 1.0.0.1 with Autopunch 1.0.0.2
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer- machine turned OFF)
  • Close software and turn off machine
  • Install Autopunch using Installation Wizard - leave CD in tray
  • Turn on Futura machine and double left click to open program
  • Type in Access Code from Autopunch jewel case and then left click on check mark to open program
To load base software 1.0.0.2 with Autopunch 1.0.0.0 or 1.0.0.1
  • Close program and turn off machine
  • Place Autopunch CD in tray but CANCEL Installation Wizard
  • Turn on Futura Machine and double left click to open the program
To load base software 1.0.0.1 with Autopunch 1.0.0.1 with Hyperfont 1.0.0.2 or Photo Stitch 1.0.0.2
  • Load Base software (have the machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Close program and then turn off the machine
  • Install the Autopunch program and leave the CD in the tray
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program*
  • Download appropriate update for Windows version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop icon to install update
  • Install HyperFont program - leave CD in tray
  • Type in Access Code from HyperFont jewel case and then left click on check mark to open program*
  • Install PhotoStitch program - leave CD in tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark to open program*
* Must open the program after installing each Option with CD in tray and type in Access Code before installing next Option.
To load base software 1.0.0.2 and adding all Options - Hyperfont 1.0.0.2, PhotoStitch 1.0.0.2, Autopunch 1.0.0.2 and Cross Stitch 1.0.0.1
  • Install Base software (have machine set-up for embroidery with USB connected to both the machine and computer- machine turned OFF)
  • Close program and then turn off machine
  • Install Autopunch program and leave the CD in the tray
  • Type in Access Code from AutoPunch jewel case and then left click on check mark*
  • Install Hyperfont program and leave the CD in the tray
  • Type in Access Code from HyperFont jewel case and then click on check mark*
  • Close Program and turn off machine
  • Install Photo Stitch program and leave the CD in the tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark*
  • Close program and turn off machine.
  • Install Auto Cross Stitch program and leave CD in tray
  • Download appropriate update for Windows version from the Futura-Support.com updates (Fut_sp2_Options.exe) and save to desktop
  • Type in Access Code from Auto Cross Stitch jewel case and then left click on check mark*
WHAT SOFTWARE CAN I INSTALL TO THE HDD OF MACHINE...
in the google write (how can i install ir3320).download and install
I am not able to install driver for D-link wifi card
The card could be bad. I've found over the years that most of these desktop wireless cards work best when the software is installed before the card is installed. Meaning uninstall all the software. Turn off the machine. Remove the wireless card. Turn back on the machine. Install the software. Once installed, shut down the machine. Install the card. Turn back on the machine and lets Windows find the card and the software.
Adobe Photo Deluxe 2.0 will not work with Vista
yes
if your machine is 64-bit Vista, then you need to install Windows XP-64bit.
you can install Windows 32-bit on a 64-bit machine, it will work. just not as good. However, you can't install 64-bit OS on a 32-bit machine.
if the machine is 32-bit then you can install any type of OS you want, you can even install them as dual boot.
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
