1997 Ford Ranger SuperCab Logo
Posted on Mar 28, 2010
Can not get quick disconnect line to release out of the transmission on 1997 ford ranger
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Mar 28, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
Helped
1639
Points
14
The quick conect lines can sometime be hard to get the springs to release. First of all you need to make sure you have the proper tool and size that will fit inside of the connection. Then sometimes you might have to slightly take a small hammer and lightly tap the release tool up into the quick connect to release the spring. This usually works for me. But you must have the proper tool to do this.
How to replace a transmission solenoid switch for a 1997 ford ranger. Automatic
1997 ford ranger. 2.3 liter sift solenoid 469a6c0b-5426-4f2b-b5c9-40b4d396597e.jpgThank You for asking FixYa.com !
1helpful
How to remove the clutch line from the manual transmission?
This can really be a pain in the ****. Ford does make a special tool for this, but it can be accomplished using a small flathead screwdriver. If you look at the quick-disconnect, you will see a plastic ring. Using a flathead screwdriver, force this plastic ring up underneath the female portion of the disconnect until the retaining barbs disengage and you are able to pull the clutch line free.
Changing clutch on a 2003 ford ranger how do I
Well to start, you need to remove the shifter from the transmission. Then remove the driveshaft. Then unplug the plugs from the side of the transmission and disconnect the clutch fluid line. Then remove the crossmember. Unbolt the bellhousing bolts. Then have a friend help you remove the transmission. Then unbolt the clutch.
I have a 2004 ford ranger fx4 4.0l. i am trying to replace the fuel filter but on of the clips that holds the line to the filter is broken. the line is still secured to the filter but i need to be able...
clean the quick disconnects with brake or choke cleen. there should be a white or green plastic button clip on the disconnect u have to squeeze the green or white rectangle button in to get it to release, the other style has a door u flip open with a small screw driver the push the the plastic catch out the back side of the quick disonnect. (they should call them quick dont disconnect ha ha )
Need to know how to change fuel filter on 2002 ford ranger, V6 sport?
These are equipped with quick release fittings. You need to purchase a set of the quick release line tools or at least the sizes for your application then simply slide them down the line into the filter and it should pop right off nice and simple
1helpful
On the transmission of my ford ranger the hidralic
you need a special tool to release the line,most major part stores carry this tool,you slip it over the line press the tool in and pull the line
Vaccum line location on transmission on 1994 ford ranger 4.0
Remove heat shield covering on passenger side of transmission. Pry heat shield from oil pan and then carefully slide it forward to expose vacuum diaphram. There's your vacuum hose!
You can find this and much, much more info in the Haynes Ford Ranger 1993 thru 1997 manual for around $20 at most auto parts stores.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
