Abit AV8 Motherboard Logo
Posted on Mar 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dear Support I'm currently reconditioning an Aleinware desktop which was D.O.A. and totally non-functional and after taking it totally apart & re-seating the CPU with new Antec Silver 5 Thermal compound & formatting the hard drive with wipe drive which took 3 days for I did a triple wipe, I re-assembled and loaded Windows XP Pro Media Center Edition 2005 32bit & Now the system is up and running perfectly. I however have been unable to locate the "BIOS" for this system in order to upgrade and or reflash, "I'm in need of the BIOS" due in-part to a virus which has infiltrated the BIOS for the system had "NO" anti-virus protection of any kind. Well here are the specs: I believe it's an Aleinware 7500 or close to this model. Sound Blaster Audigy 2ZS (Sound Card) P.S.U. (Power Supply) Aleinware HPC-420-302 DF The system has a sticker on the back which reads as follows: Aleinware Corp Support 866-287-6727 VGA Card: GeForce 7600GT Motherboard: Abit AV8 Motherboard Socket 939 CPU: AMD Atolon 64 3800 /2.5 GHz ADA3800DEP4AW Processor AMD Athlon? Model 3800+ OPN Tray ADA3800DEP4AW OPN PIB ADA3800AWBOX Operating Mode 32 Bit Yes Operating Mode 64 Bit Yes Revision CG Core Speed (MHz) 2400 Voltages 1.50V Max Temps (C) 70 Wattage 89 W Virtualization No L1 Cache Size (KB) 128 L1 Cache Count 1 L2 Cache Size (KB) 512 L2 Cache Count 1 L3 Cache Size (KB) 0 CMOS 130nm SOI Socket 939 AMD Business Class No Black Edition No Chip: VIA VT8237 Ram: Corsair Value Select VS1GB400C3 (4 x 1GB)
Anonymous
Level 3:
Genius:
  • Master 1,027 Answers
  • Posted on Mar 28, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1027
Questions
0
Helped
380341
Points
2770
I don't think that you need a bios upgrade for a 'virus' infection - they generally don't go there, as modifications to the flash memory can be tricky and difficult without knowing the flash type; viruses generally affect OS areas as being much easier.
What is the error code f03 on the vector 1092 bettery charger
F03 - Sulfate or Unchargeable Battery
Appears when the battery is highly sulfated and cannot accept normal charge current.
• Follow the steps in "Recondition Mode" to recondition the battery.
• Follow the steps in "Equalizing" to equalize the battery.
• If the situation persists after reconditioning and equalizing, we recommend taking your battery to a certified automotive service center for evaluation
2answers
How to compute 3 phase load if the total load is 210 amperes?
Assuming the circuits are balanced the load in each phase will be 70 amperes.
1helpful
How can i reset the Non-resettable Grand Sales Total at the Casio TE-M80? I just bought a used Cash Register & need to reset it. Many thanks, Helge
The answer may be in your question... "How can I reset the non-ressettable..." you could try ringing Casio, but you might not be able to. Sorry
Dell Precision 530 with dual Xeon CPUs. Uses Rambus memory. (4) 256mb ECC modules are installed. It should be a total of 1 gb. However, BIOS only shows 256mb total even though it shows all 4 rambus...
It sounds like like you have multiple issues. When all memory slots are filled with 256 sticks the computer boots but only sees 256 MB instead of 1 gig.
When you install the Crimms it won't boot at all.
You may have an open circuit on one of the Crimms.
As for the computer seeing only 256 MB you may have a bad memory slot on the motherboard.
Here's a link regarding Direct Rambus DRAM or DRDRAM (sometimes just called Rambus DRAM or RDRAM: http://en.wikipedia.org/wiki/RDRAM
Memory card renders camera non-functional (std sd card)
There are memory card utilities that can fix the card, but you have to use a card reader with your computer. Here is a link:
http://www.google.com/#hl=en&source=hp&q=sd+memory+card+recovery&aq=4&aqi=g10&aql=&oq=SD+memory+card+&gs_rfai=CiTrZeWcvTIrKHKCYNOXTzbsIAAAAqgQFT9A8m-w&fp=4cb5f508e49085f6
As you can see, there are many sites, and some have free trials. That's about all you can do, unless you buy another card. If another card doesn't work, you might have a physical short on the memory pins inside the camera, and that's requires taking the camera apart, and straightening them. There's not much to taking the case apart, but you might have to disconnect a ribbon cable or two. You can pry the cover off the memory card holder, and see the contact legs.
That's about all I can think of, good luck, and hope this helps.
Have Powermatic Planer & can't get the infeed & outfeed rollers adjusted right. Takes all you have to operate it. 24" Planer less than 10 years old & probably doesn't have 200 hours total on...
The rollers may need to be reconditioned. Try cleaning with a solvent to soften them up. I hope this has been helpful please rate if this answer has been of any help. Good Luck and have a great weekend.
What kilowatt rating is the ck408 can you tell me how most electricians have wired these appliances have they put 3 x 4mm cables to this appliance or 1 x 10mm cable instructions not very clear & what...
look on the unit tag just inside oven door (on most) and it will tell you kw or take input volts and multiply by total current draw and this will give you watts then divide by 1,000 for kw,your total draw in current will tell you what size breaker you need
Cannmemory slot on e-system laptop
No crucial is counting the slot with the memory in it along with the empty slot and gives you a total of 2 memory slots.
2answers
Sony explode amp ''OVER CURRENT'' light on -no sound
just feed 240V through the RCA inputs and check if the amp power light comes on. if it does the the amp should have automatically been reconditioned.... you are now ready to rock n roll!!!
I have an old Palm M125 monocrome hand held unit and have not used it online before now. It has software for the desktop etc on CD but it is too old for windows vista. I do not have outlook on this PC. The...
Older palm products and vista aren't compatible. You either needs to transfer info via bluetooth or upgrade your palm if you wish to continue using vista.
Top Abit Computers & Internet Experts
ExpressFiX
ExpressFiX
JTR44
Level 1 Expert
Grand Canyon Tech
Grand Canyon Tech
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
