Question about Connex 4600 Base CB Radio
Connex 4600 turbo radio stays keyed up even with mic disconected
Posted by outlawtex1 on
Jim Verge
    New Friend:
  • 35 Answers
Bad RX/TX Transistor? I don't have a diagram for the 4600. Sorry!
Posted on Apr 03, 2010
Will a connex 4600 turbo cb radio operate cool enough in a dash enclosure?
I have CX-4600-T too. Mine gets way hot as well, I had a mod kit installed n it swings 215W peak power now. But the excessive heat is annoying, I think mine does have a fan in it though cause I know I felt air coming out the back before.
May 26, 2014 | Connex 4600 Base CB Radio
What is the best power mic for the ranger vr 9000
Astaic 36L. You never want to run a power Mike with a good radio with Mic Gain. Road King is great to. It is very hard to find the honey spot with a power Mike when you have Mike gain on radio.I think it is pretty hard to beat the 36L. I use one one my Connex 4600 Turbo and Galaxy 95T2, They both performe great. Connex is a little better a DX ing though
Nov 22, 2013 | Ranger VR-9000 Base CB Radio
I have a connex 4600 turbo with a road king 56 noise canceling mic. My mic just started making a cracklin sound in my external speaker . It also shocks and burns me. When I key up and let go it stays keyed...
Sounds to me like the RF signal is leaking into the microphone. Check the cable to the microphone and see if the ground wire is bad. Check the SWR to see if it is high. The problem you are talking about is unusual.
Jun 28, 2013 | Radio Communications
I av a connex 4600 turbo and a astatic 636 mic on it when i turn the talk on it squeals bad how do u stop it
turn down the rf gain. If that doesn't work you may want to have some one install 2 .001 caps across the tx and the dx wires in the mic.
Mar 18, 2013 | Radio Communications
I have a connex 4600 turbo very good radio!! But the other day I keyed up my mic and the radio shut off but came right back on when let go. Do u know what that might be?
check for any loose power connections.. ground connections.. loose coax.. also make sure vehicle is on so not to drain battery down when TXing. if it was off it may have dropped battery voltage down lower than it should... and turned off.. RX doesn't use hardly any ampres..
Mar 28, 2011 | Connex Radio Communications
I have a Connex 4600 Turbo mounted in the headliner of a W900L Kenworth using Wilson 2000 twin antennas and a RK56 mic. When trying to use the "talk-back" feature all I hear is constant...
Strange. You shouldn't have a squealing problem with an RK56 noise canceling mic.
Unfortunately there is no way to change the volume of the talkback. Its too loud. The only solution is to turn the mic gain down.
The only reason you need to have talkback on is to check your audio. Make sure the echo is good and what not. After that you really don't need it on. So turn down the mic gain, then check the echo, then turn off the Talkback and turn the gain back up.
The squeal is feedback from the talkback being to loud and being heard by the mic. So the only way to solve it is to lower the volume of the talkback, (Which is not possible in this radio) lowering the mic gain(which lowers your audio level) or turning it off.
Nov 08, 2010 | Connex 4600 Base CB Radio
Connex 4600 turbo the talk back
THE TALK BACK VOLUME IS CONTROLLED BY THE MIC GAIN, TRY ADJUSTING YOUR TALK BACK VOLUME ABOUT TURNING THE MIC GAIN FROM 12 OCLOCK TO 6 OCLOCK, DO NOT WORRY YOU WILL NOT LOSE ANY OUT BOUND POWER UNLESS YOU TURN THE MIC GAIN BELOW 11 OCLOCK
Mar 29, 2009 | Connex 4600 Base CB Radio
Connex 4600 Turbo
i have the same radio turn talk back off and there is enough power ull have talk back through you trucks radio speakers and it needs to be hooked up to the battery with at least 12ga wire
Feb 10, 2009 | Connex 4600 Base CB Radio
Frequencies
i have a 4600 connex and if i turn the mic gain all the way up i get alot of modulation.can someone tell me how to fix that?
Feb 01, 2008 | Connex 4600 Base CB Radio
Radio Communications Logo
262 people viewed this question
Top Connex Radio Communications Experts
Tony Raia
Marvin
Marvin
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
