Question about Kenmore 12.8 cu. ft. / 362 liter Chest Freezer 13312
Philco Chest Freezer @ 12.8 cu.ft - no part number. If there were ever a part number, it has long since fallen off. The rubber seal is dried out[and is practically rock solid], while the plastic around the top is cracked and disintegrating. How do I replace or repair the seal and plastic sections? [Ordering parts seems to NOT be an option because of age.] Thanks.
Well, you can find a universal gasket kit. Instead of being one solid piece specifically made for you model, It is made up of pieces that you cut to fit. I should warn you that these kits are very difficult to work with. If you dont create an air tight seal, the constant warm air leak will make it run longer, decreasing its useful life.
You said however that the gasket is only dried and rock hard, not that it was torn or falling away from the door. If that is indeed the case, and you still have good tight seal on all four sides, you might be ok for a while.
factory replacements are nearly impossible without a model number for reference.
Posted on Mar 29, 2010
Good day,
Unlikely you would be able to repair if the inner liner is coming apart.
A local appliance parts house may be able to supply universal gasket to fit to the machine but again, if the inner liner is bad it could prove to be fruitless.
Oddly enough, if you visit supermarkets you will see chest type freezers with no top at all.
Seems like a terrible loss, but it's not.
Cold air falls, hot air rises. When the freezer generates cold air it doesn't spill out the top. It settles into the bottom of the freezer, and stays there. Likewise, warm air rises and has no interest in going into the freezer cavity.
Bottom line. Very little loss.
If appearance doesn't matter, and you can get it close, you should be able to continue to use it.
Your choice, but I thought you would like to know the physics involved here and how it does or doesn't affect you.
Posted on Mar 28, 2010
Sep 14, 2014 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Feb 28, 2011 | Magic Chef 7 cu. ft. / 198 liter Chest...
Dec 16, 2010 | Magic Chef Chest Freezer MCCF5WBX
Dec 04, 2010 | GE 19.7 cu. ft. / 558 liter Chest Freezer...
May 05, 2010 | Maytag 20 cu. ft. Upright Freezer MQU2056B
Nov 10, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Apr 30, 2009 | Zanussi 5.76 cu. ft. / 163 liter Chest...
Nov 25, 2008 | GE 5 cu. ft. / 142 liter Chest Freezer...
Nov 21, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Nov 27, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Sep 18, 2014 | Kenmore 12.8 cu. ft. / 362 liter Chest...
1,061 people viewed this question
