Question about Onkyo TX-SR603X Receiver
Power outage overnight. Now, Onkyo TX-SR603X no
Power outage overnight. Now, Onkyo TX-SR603X no longer functions correctly. When Video 1 is selected, Video 2 diplays on output (TV) with no sound. When Video 2 is selected, DVD is displayed on output (TV). Very confusing. Has anyone seen this before?
  • Anonymous Mar 30, 2014
    video output does not display video
ABRsvcs
  • 4,234 Answers
Depending upon the type of power outage, you may have more of a confused receiver than a defecive one. Try unplugging the unit for an hour or so to see if that resets the whole thing back to "normal". If not, then further investigation with a scope or logic analyser will be required to determine whether the problem is with the internal CPU or a defect on the data lines. Unless the reset works, this is not likely to be a DYI repair.
Dan
Posted on Mar 28, 2010
Testimonial: "Appreciated. I'll try to "reset" tonight."
I Have The ONKYO TX-SR603X receiver ALL BY ITSELF I NEED HELP RESETTING IT
Hello, please see the procedure below to reset the receiver
Resetting the AV receiver to its factory defaults To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VIDEO 1] button, press the [STANDBY/ON] button. "CLEAR" will appear on the display and the AV receiver will enter Standby mode
Apr 26, 2017 | Onkyo Audio Players & Recorders
How can I run a turntable through the onkyo tx-sr603x?
Look on the back of the system, if there is phono input, that is what you can use to connect the turntable without using an external pre amp
Aug 27, 2011 | Onkyo TX-SR603X Receiver
I have an onkyo receiver tx-sr603x. I can get
audio amplifier´s damaged need to be replaced
May 25, 2010 | Onkyo TX-SR605 Receiver
Onkyo TX-Sr603 goes back to standby when press On button - help!
does not sound like the fuse.
its easy to check. unplug unit and remove the cowling / shroud of the unit. the internal fuse will look like a car fuse. the old round style about 1" long and 1/4" round.
sounds like a bigger problem. hope this helps.
Feb 19, 2010 | Onkyo TX-SR603X Receiver
Programing a Onkyo Universal remote control
Not to be found. Your remote controls a lot of functions, and as such can be confusing to program properly. I can only suggest two things, one, sit down with pages 14-18 of your user's manual and use some patience finding how to work it. If you do not have a manual it can be found at manualslib.com and look for this search result ONKYO TX-SR603X INSTRUCTION MANUAL Pdf Download. with manualslib.com underneath. Your second option is too take it a repair shop or knowledgeable audio/video dealer and have them program it for you.
Oct 25, 2017 | Onkyo TX-SR603X Receiver
ONKYO AV RECEIVER TX-SR603X
When I initially bough mine, I had the same problem. It wouldn't shut down, but occasional popping sound on the center speaker. Turns out the impedance on the speaker was 4 ohms, not not 8. Replaced center with an o 8ohm speaker. This receiver is not reated to run 4 ohm speakers. If I had problems with 1, I can only imagine what kind of problems could happen if all the speakers were 4-ohms.
Oct 14, 2007 | Onkyo TX-SR603X Receiver
Remote control for onkyo receiver
My situation is different. The remote control can turn on the unit and all functions are working, except that I cannot turn it off using the remote control. Anyone know why and how to fix it?
Aug 27, 2007 | Onkyo TX-SR603X Receiver
Onkyo TX-SR603X Receiver Logo
484 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
