Install disk says that op system, windows 7, does not support this wireless, but sales person said it does. What to do?
The router is compatible with Win7 according to the Microsoft Compatability Center. The CD is not needed during the install. The smart wizard is pre-installed in the router management software on the unit. Point your browser to http://www.routerlogin.net and login (http://kb.netgear.com/app/answers/detail/a_id/239/session/L2F2LzEvc2lkLzZ3RVJkKlhq ) gives the default account information. Then click on the Setup Wizard at the top of the left-hand navigation menu.
I hope this helps.
(I suspect the CD is useful if you need the manual but it's autorun files are for an older OS.)
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
