Question about Kenmore Freezer 13.7 cu. ft. Upright Freezer
The high temp light is on. What can I do to reset it? Everything seems frozen and fine in the frezzer
Posted by rawlingj on
Anonymous
    Novelist:
  • 185 Answers
HIGH-TEMP ALARM SWITCH (SOME MODELS)
An audible
alarm will sound if the freezer temperature reaches
unsafe levels. The alarm operates on household electricity.If
the power
fails, the alarm will not perform.
An ON/OFF switch
allows the high temperature alarm to be
deactivated if desired. NOTE: You must open the
freezer door to
view the alarm switch. The
freezer is shipped with the switch in
the OFF position.
After the freezer has run longenough to
lower the temperature, you
may set the switch to the ON
position.
To activate the alarm, set the switch
to the ON position.
To deactivate the alarm, set the switch to the OFF position
i got this from the freezer manual from Kenmore hope this was helpful
Posted on Apr 04, 2010
What is the suction pressure low side and high side charging 404a refigerant cooling temperature
evap temps usuall run 10-15 degrees below the box temp.This a generally accepted rule of thumb.
Sep 15, 2014 | Delfield Freezers
I have a hotpoint freezer fza34 The red high temp
it could be that your fridge,freezer setting is not turned up high enough to keep the freezer cold enough.turn it up to setting number 5 at least and if that dont do it u could have a faulty thermostat.have it checked by a engineer.
Oct 30, 2013 | Freezers
The high temp light is on, liquids are now liquid,but the meat is still frozen. I live in west central mich, and the temps have been in the high 80's and low to mid 90's with relitive high humidity, about...
Not normally,Make sure you door is sealing properly also check and make sur ethe evaporator fan is running when the freezer is in a cooling mode.you may need to remove the rear panel of the freezer and check for frost build up.if there is frost build up then defrost the evaporator with a blow dryer.
then check the continuity of the heating element and make sure it is in working order.
Aug 31, 2010 | Frigidaire 14 cu. ft. / 396 liter Upright...
Ge frezzer goes into defrost mode and defrosts EVERYTHING! Ice cubes refreeze solid as one. HELP!
sounds like your defrost termination switch is not cuttin off heater when ice on evap melts.switch is surpose to cut off heater when it reaches a certain temp. replace defrost termination switch
Aug 27, 2009 | Freezers
Temp Alarm going off, when freezer seems to be cooling fine.
You need to check the temp in the freezer to make sure it's down to around 10 degrees. The alarm will go off much above that.
Jul 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
The alarm light is flashing, the freezer seem to be working,
Most all cooling systems need to be in an ambient temp of about 60-65 degrees. If not, it needs a low ambient control. This helps keep the high side pressure high enough so you have the proper pressure drop accross the expansion device. This applies to coolers, freezers, a/c units, and so on. I also think, if it keeps things frozen like you want, where's the problem? You make have a control just acting stupid.
Feb 07, 2009 | Freezers
Temp alarm on freezer alarming.
that's the same problem i incurred, i replaced the thermostat and the fan. seems to be working fine.
Dec 03, 2008 | Kenmore Freezer 14.1 cu. ft. Upright...
Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
Dec 28, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Temp alarm going off
What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting Need to check the temp to make sure its cold enough.. thats what that alarm is for
Aug 10, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore Freezer 13.7 cu. ft. Upright Freezer Logo
2,061 people viewed this question
Top Kenmore Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
