Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Temp set at 5(as always) but food in the refrigerator is freeezing. Ice maker and water distpenser do now work. just started happening.
Posted by cherie_mcada on
T Decker
    Scholar:
  • 104 Answers
Try unclogging the drain line for the freezer. What seems to be happening is your refrigerator is working too hard to keep the temperature that it reads inaccuately. Usually a light defrost will do the trick , sometimes a longer defrost or one using warmers...don't be too tempted to use anything like a hair dryer for safety reasons.
Make sure you keep your frig door closed and use the frozen food in the frig to hold temps down.
Good luck.
Posted on Mar 28, 2010
Ice maker makes ice but freezes before it can be dispensed so the dispenser is always clogged with frozen ice. Cleaned out the ice maker and started over but same results. The temp is set at 38 for the...
Hi, The freezer should be "0", the possible clogging you have could be a leaking water valve or an over filling ice maker. I would have the ice maker checked for volume of water dispenser during harvest, should be 5.5 oz. (2/3 cup), if more the 6 oz. the ice maker is bad. If fails to stop filling or leaks/drips, replace the water valve behind the unit.
I hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 27, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
Amana AFI2538AES The refrigerator portion keeps freezing the fruits and vegetables. The chiller control is on the warmest setting and the refrigerator temp is set at 43. I have been raising every once...
Our Amana afi2538aes is doing the same thing. Had a repairman out. He called tech support at Amana. They had him adjust the "thermistors" but it is colder than ever running at 28-30degrees in the fresh food compartment despite being set at 46 degrees. Tech support also recommended installing some sort of "ice bin seal kit to take care of the problem" according to our invoice from repairman. Repairman was told that the ice bin in the fresh food compartment puts cold air out (to keep the ice frozen) which freezes the food in the fresh food compartment. I called Amana and the rep I spoke to said he couldn't find record of this being a problem with the model but tech support told our repairman "we've had a lot of problems with this happening."
Mar 31, 2011 | Amana AFI2538AES Stainless Steel (256 cu...
Icemaker not working...
Hi, first , pour about 2/3 cup of water into the ice maker . If if freezes , and dumps , replace the water valve. If it does not dump the cubes , replace the ice maker. After pouring the water into the ice maker , remove the bottom kick panel , and clean the bottom coils , of dust , lint , pet hair , etc , as this will raise the freezer temp . An ice maker has to be 5 degrees , to operate , correctly . If ice maker starts working , after cleaning the coils , GREAT ! ( it does happen ) .
Take care
May 28, 2010 | KitchenAid Superba KSRG25FK Side by Side...
My refrig stop making ice after I changed the water filter. I had the filter out for about 3 hrs, would this cause the problem?
Take care
May 28, 2010 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
My icemaker just stopped making ice today....please help
Take care
May 16, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My icemaker just stopped making ice - i can feel frozen ice in the top but it doesnt dump any ice out?
Take care
May 13, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
The ice maker just stopped making ice.
First , pour about 2/3 cup of water into the ice maker . If if freezes , and dumps , replace the water valve ( pt. # 4389177 ) . If it does not dump the cubes , replace the ice maker ( pt. # 4317943 ) . After pouring the water into the ice maker , remove the bottom kick panel , and clean the bottom coils , of dust , lint , pet hair , etc , as this will raise the freezer temp . An ice maker has to be 5 degrees , to operate , correctly . If ice maker starts working , after cleaning the coils , GREAT ! ( it does happen ) .
Dec 04, 2009 | Whirlpool ED2FHEXN Side by Side...
New ge fridge temp on door does not agree with three different temp gauges i have placed in the fridge. 5 to 10 degree difference?
That will happen easily if the temperature probe/thermistor is covered or located behind something stored near it. The door reading also could be out of calibration. If you have an ice maker the ice maker will not want to work very well above 5 degrees. If you run into major problems or this just started happening and you notice changes in the fresh food compartment goes above 38 degrees then that could be the beginning of a defrost problem. If you should need help let me know, Thanks, Sea Breeze
Nov 22, 2009 | GE PFS22SBSSS Stainless Steel French Door...
Water dripping in Freezer leaving ice all over food
need a new ice maker for the leak but the temp is another thing
Nov 29, 2008 | GE GSS20IEP Side by Side Refrigerator
GE Profile Arctica - Frig Freezing Food
Replace the damper assy, in the Refrigerator section. The damper door is stuck open. Very common problem on these refrigerators.
Nov 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
96 people viewed this question
Top Refrigerators Experts
Vish Iyer
Vish Iyer
gbob59
