Question about Qca Spas Dream Series Dream Master Hot Tub with Flex Cover
'Sn' is a general error message relating to the temperature sensors.
Assuming that you have a Balboa spa pack (M7 version), turn off the power and remove the spa pack cover, you'll find two temperature sensors mounted in the top of the heater tube one at each end. Follow the wiring from the sensor to the plug(s) on the PCB and check that the connections are good, they have a habit of devekoping a poor connection.
If you have a multimeter you could also check the resistance of the two sensors. They should both be the same. If they aren't the same you'll probably have to replace them.
One final thing just to check... Ensure that there are no blockages within the heater. Unless you have service/gate valves you will have to drain the hot tub, unscrew the unions and check inside the heater for debris within the heater assembly.
If you're from the UK I may be able to help regarding parts etc.
Kind Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 08, 2010
Jun 28, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
Nov 03, 2013 | Qca Spas Dream Series Dream Master Hot Tub...
Oct 27, 2013 | Pool & Spa
Dec 01, 2012 | Intex Automatic Salt Water System for ...
Apr 17, 2012 | Pool & Spa
Jun 12, 2010 | Pool & Spa
Oct 04, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
Sep 29, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
2,251 people viewed this question
