I need an instruction manual for a Brother Correctronic GX-6750 Electronic Typewriter
Here you go...I hope this will help you... http://www.softwaredriverdownload.com/brother_gx_6750_user_manual.html
SOURCE: User's manual for typewriter GX-6750
Click on the link in the thread. This should open up an Amazon page. About halfway down (in quite small writing) is a link to a user manuak. You will need Adobe Reader to view it though.
SOURCE: correction tape
To replace the correction tape:
1) use [SPACE BAR] or <<-¦ to move the carrier to the centre of the platen
2) open the top cover
3) remove the cassette ribbon (if installed)
4) pull off both spools, pressing against the correction tape with your thumbs. Bring it back to a position parallel with the platen and lift it up and out.
5) Pass the new tape through the left guide, behind the ribbon guide, and out thropugh the right guide. The rough (stick) side of the tape should face the platen.
6) Attach the feeder spool to the pin on the left
7) Attach the take-up spool to the pin on the right
8) Turn the take-up spool counter-clockwise until a small amount of white tape has wound around it
9) Replace the cassette ribbon and close the top cover
10) Press 'spider web' key +// to move the carrier to the previous position.
Hope this helps.
Regards TC
SOURCE: Brother GX-6750 Daisy Wheel
Install wheel, turn machine on and off this resets the printer and home timing. If it still does not correctly, adjustments needed..
SOURCE: I need an owners manual
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_GX6750_EN_214.PDF
Download a manual at the above link.
SOURCE: How do you get to the instruction book to download
http://www.devicemanuals.com/downloadguide.php
http://www.manualnguide.com/manual-get/11872/
The above two links are the places are you can download the manual free of cost.
Download it and make it a useful one.
Rate my solution if satisfied.
I suggest you download the manual. You will need to know more
things like how to set the margins and change pitch. The correction tape
instructions are page 11.
This link is to the full manual http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_GX6750_EN_214.PDF
