Re: turn on the power and the camera beeps 3 times?
Hmmm... accesses the card ok? 3 beeps on a computer is a memory thing... might try a differnt SD card... Otherwise, probably is trash, cameras are so cheap that having a shop repair them is just not worth it.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Turn off your LCD display screen. I know this is hard—who likes shoving their face against the camera to compose a shot through the little viewfinder? But the LCD screen single-handed-ly drains a lot of power.
Minimize the picture preview to the least amount of time possible—usually one second. This uses less LCD screen time, thus less power.
Dim the brightness on your LCD screen. A dimmer display extends battery life by consuming less power to light the screen. This might make the display harder to see, but usually only in direct sunlight.
Set the power saver to the least amount of time. Power saver lets your digital camera “sleep” when not in use, but doesn’t shut it down entirely. To “wake up” your digital camera, simply click the shutter button.
Use your zoom as little as possible. The motor that moves the lens uses power. This also goes for repeatedly turning your digital camera on and off if it has an extend able lens.
Turn off the continuous focus. Again, constantly using motors and electronics to ready your shot drastically minimizes battery life.
Don’t push the shutter button half-way down until you’re ready to shoot. Pushing the shutter button (constantly resetting and refocusing) will drain battery life.
Use the flash only when necessary. Your digital camera’s “auto flash” option should take care of this, but make sure your flash isn’t going off in broad daylight.
Don’t delete pictures from your digital camera unless necessary. This consumes power. Wait until you download the pictures to your computer before deleting.
This one’s basic, but charge your battery often. Lithium ion batteries, which most digital cameras use, don’t have “battery memory” like older alkaline. In fact, lithium ions work better and last longer if charged completely and regularly.
press menu, go to play symbol (blue highlighted tab at top of screen) Scroll down to option 5 "review time" and you can either turn it off or set it to what ever time is available
Sounds like you accidentally pressed the DISP button on the back (it manually turns the LCD screen on and off to save batteries). Turn the camera on and press the DISP button once. Hopefully that should fix it.
Is it an actual beep, or is it a beeping noise coming from the lens? Does the lens extend? I ask this because this is the noise the lens focus gears make when they are knocked out of alignment, or debris gets in them and jams them.
I HAVE SOLVED THIS! I Totally fixed my CAMERA! If you turn on your camera, the lens does not come out, and it just beeps then turns off, then listen to me. You need to unscrew the outer casing and take off the metal shell. Hold the camera in one hand, palming it, looking down at the LCD (ie the lens is pointing into your palm). This is to orient you. If
you look at the left SIDE of the camera, near the upper left corner of
the LCD, you can peek through some of the windows of the black plastic casing
and see 2 PLASTIC GEARS. The top one is white, the other is black. These are
the gears that actually move the lens in and out. All I did was give
the white gear a good jiggle with the tip of a pen and evidently it
made the teeth of the gears mesh together like its supposed to and ....
VOILA .... the lens came out when I powered it on and all is well! I
know this is gonna help someone!
No solution for your first problem but it's normal that you cannot view your photo on the LCD screen before actually taking it. Due to the way a reflex camera is built, you can't have a live view on your LCD. The Fuji S3 Pro has this type of preview as also most recent camera (Nikon D300, Canon 40D...).
Well, after a little more googling, I'm embarrassed to say I've found the solution. I must have somehow pressed the display button which turned the preview display off. I tried pressing all of the buttons before I made my previous post, but apparently i didn't press it. :(
This is the lens motor not responding
Nothing for you to do there any repair is likely to be expensive
Contact Panasonic for further advise
a New camera perhaps
