Samsung 906BW LCD monitor , power switch light turns on, but the monitor won't turn on
This model is released in June 2007, more likely to have bad caps by now, just other failed SAMSUNG monitors here: http://s807.photobucket.com/home/budm/allalbums
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Post back what you find.
Rommelnmariv, 906BW will need to use warranty or if you are not a tech with soldering equiptment then unit will need to visit a tech to be evaluated for it's Black screen or It's Blank n Black screen problem. Read my older fixya responses (late 2009) and follow all links. Yes, some of these can be fixed-up (DIY) for under $10. Read my fixya profile for about an hour !!! Maybe you will ask your 906BW " What Brand of capacitors do you have inside you??" Bye for now. 12fixlouie
