Question about Konica Minolta bizhub 250 All-In-One Laser Printer
INSTALL SO I CAN PRINT
I nid to set up the printer so I can print through a local network
Posted by gabistomax on
taminol
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 62 Answers
There is no attachment functionality on this fixya site, so here is a link to a PDF (which I found floating around on the web) it shows how to connect a Konica Minolta to a network. The guide covers lots of Operating Systems. Please have a read and then follow the correct one for your situation and environment.
http://www.kpshelpdesk.co.uk/files/Konica%20Minolta%20Printer%20Setup%20Guide%20V1.11.pdf
Kind regards
m-press.biz
Posted on Jun 15, 2010
Envelope oreintaion is not correct to print #10 envelopes
Is this a networked or local printer? If local make sure those settings are properly set, same goes for the networked printer but on the server side.
Jan 02, 2018 | Mysoftware My MailList & AddressBook...
Vista driver
The print driver solution for this product is included with the Microsoft Windows Vista operating system and is already on the computer. No special driver download is necessary for this product.
Please follow the simple instructions below to easily get the product working with Microsoft Windows Vista Operating system.
Installation Instructions
Direct Connection (Parallel & USB connector)
  1. Verify that the printer is turned ON.
  2. Connect the Universal Serial Bus (USB)/ Parallel (IEEE 1284) cable to the printer and to the computer
  3. Click on the Close button when the message "Your devices are ready to use" is displayed in the screen.
  4. The printer is now ready to accept the print job.
Wired Network & Bluetooth Connection
NOTE:For Bluetooth connected printer, please ensure that the printer's access mode is set to public mode for detection.
  1. Verify that the printer is turned on.
  2. Click Start > Control Panel and then select Printers .
  3. Click on Add a printer .
  4. Click Add a network, wireless or Bluetooth printer . A list of detected wired network or Bluetooth printers will be displayed.
  5. Select the printer you want to install and click Next . Follow the on screen installation instruction to complete the printer driver installation.
Wireless Connection
  2. Ensure the printer's wireless network setting is set to the correct wireless profile matching the local wireless network/computer's wireless card setting.
    If you have previously configured the printer's wireless network setting, matching local wireless/computer's wireless card setting, please proceed to step 3.
    if you have NOT previously configured the printer's wireless network setting to match local wireless network/computer's wireless card setting, please follow the steps below.
    To set wireless network settings in an infrastructure network
    Connect the printer to the computer with the cross cable (included with the printer) or connect the printer to the network with a network cable.
    Press the configuration button once to print a configuration page.
    Open web browser, and type in the IP address that has been assigned to the printer.
    Configure the printer's wireless setting to match local wireless network/computer's wireless card setting.
    Unplug the cross cable/network cable.
    Activate the printer wireless network, activate the computer's wireless network profile.
    Proceed to step 3.
    To set wireless network settings in an ad hoc network
    Do the following to reset the printer's network settings:
    1. While pressing the Configuration Page button, press (Resume button) three times.
    2. Wait about 20 seconds, and then press (Power button) to turn off the printer.
    3. Disconnect the power cord from the printer.
    4. Wait about 20 seconds, and then reconnect the power cord.
    5. Press (Power button) to turn on the printer.
    6. Open the configuration utility for the computer's wireless network card, then create a new wireless profile with the following values.
      • Communication mode: ad hoc
      • Network name (SSID): hpsetup
      • Security (encryption): disabled
    7. Activate the wireless profile.
    8. Wait two minutes for the printer to obtain an IP address, then print a wireless configuration page to verify the following for the printer's network settings.
      • The IP address is NOT 0.0.0.0
    9. If one of the above conditions is not true then repeat the preceding steps. Proceed to steps 3 below.
  3. Click Start > Control Panel and then select Printers .
  4. Click on Add a printer .
  5. Click Add a network, wireless or Bluetooth printer , a list of detected printers will be displayed.
  6. Select the printer you want to install and click Next . Follow the on screen installation instruction to complete the print driver installation.
Dec 15, 2013 | HP DeskJet 450wbt InkJet Printer
Looses connection with network
Common for this printer. Instead of setting it up as a network printer, attach it locally to a machine and share it. It will be much more stable.
Aug 09, 2012 | Lexmark T620 Laser Printer
How can i set my printer to my roter
This is non network printer, you can't print just like a network printer , but you can install the printer in local system and share it & install the drivers in desired systems through local system where printer was connected. It will work like a network printer but scanning is not possible to other systems except local system.And one more drawback is your won't get print, if local system is switched off..
Nov 21, 2011 | HP LaserJet 3050 All-In-One Printer
You have to set up the machines network settings.
Press Utility/Counter
Select Admin
Enter Code 12345678 or 00000000
Select Admin 2
Select Network
This is where you can put in the IP, Subnet, Gateway, and DNS.
Then install the print driver. It is best if you have the driver disk. If not you can download the driver from kmbs.konicaminolta.us
If you have windows 7 download the XP version for your operating system (32bit or 64bit)
May 15, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Difficulty printing to DNS 323 attached printer
Try going into Kaspersky, settings, firewall, and then select the network tab. Under the local network tab you may find the security is set too high, and this is what is blocking the print run. Settings from high to low are Public > Local > Trusted. Change the security setting down for your LAN the printer is on to Local, or trusted if you know what you are doing. Worked for me. I had similar problem - printing worked, then installed Kaspersky on all machines and printing became erratic on wife's laptop.I had different settings on the wife's network settings for her wireless and wired LAN, and I think the erratic behaviour came from fact that one of them was public, and one local. Changed down and all was fixed.
Sep 15, 2009 | D-Link Dns 323 2-Bay Network Storage...
Infoprint 1120 printer
If you are doing it as a local printer ( parralel cable or USB it can be done through Start, Settings, Printers and faxes, Add a printer.
Network is different.
You have to assign or let it get an IP address from the network.
You can enter it manually in the printer
Hit the left arrow to
Network menu
hit select
Standard net setup
hit select
Print ( to print out the network settings)
scroll to TCP/IP
select
enter IP manually by scrolling to each number and hitting select
Sep 18, 2007 | IBM Infoprint 1120 Laser Printer
4600n
Can't come to VA but will the printer print a test page from the pannel?? Check the net card setup. Is it a shared local printer and set to work ofline?
Aug 23, 2007 | HP LaserJet 4600dn Color Printer
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
94 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
