Question about Princeton Digital VL1514 Monitor
"no signal" princeton screen won;t work anymore, it now only shows a "no signal" screen adn shuts off, tried replacing coord, moving coord to other ports and tried different coord al together. nothings working still get smae signal.
Posted by cagedlovebir on
Anonymous
    Guru:
  • 341 Answers
"no signal" means that the monitor is not receiving a video signal from your computer or laptop. This is normal if the compouter is OFF and the monitor is ON. Is the computer still on and connected to the monitor?
Posted on Mar 27, 2010
Ilo won't work with ps3
The set receive no signal at all. It will be best get it repaired by any experienced service technician.
Apr 22, 2012 | iLO 3200 32 in. LCD Television
Princeton Digital (VL1916) 19" LCD
Try to decrease your screen resolution. see attach picture: or restart your computer then if windows xp booth press F8 then choose ENABLE VGA MODE. press enter. jimmyverdade_4.jpgjimmyverdade_5.jpgjimmyverdade_6.jpg
May 27, 2011 | Princeton Digital VL1916 19" LCD Monitor
My Princeton 19 inch LCD monitor keeps turning off and I have to un-plug it, wait, and plug it back into the wall socket for it to go back on. I replaced the multiple box and the power cord and am using...
bsims77010, Tell me brand name of electrolytic filter capacitors on the large "switch-mode-power-supply / CCFL inverter supply" printed circuit board. Are any of them SWOLLEN on the end that is up ??? You can see typical "failed units if you visit YOUTUBE for video clips that show owners/tech's that replace them with new ones and now have working units again. You must tell me more about this "keeps turning off" thing???? Is unit going to "black screen" only?? Or is it going to "black n blank" screen"??? There is a difference!!! If black only then 5vdc might be ok! If "black n blank then +12vdc & +5vdc sources could be in shut down mode. Do you see screen data with aid of bright flashlight held 1 inch from the "black" screen?? Once you have knowledge of what makes "raw white light" on reverse side of your lcd panel, then you will have clue to how the new screw-in, curlie-Q style CFL light bulbs work and what an "electronic ballast" circuit is. 12fixlouie
Post reply if you need further assistance.
Dec 14, 2010 | Princeton Digital VL1919 19" Monitor
Princeton vl 1918 monitor on screen it says check cable no signal. how do you obtain signal?
You need to verify to find out if it is the monitor is bad or the PC is not sending the video signal to the monitor. Try another monitor with the PC, if you still have the problem then you need to fix the PC, if it works OK then it is the monitor problem.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Oct 08, 2010 | Princeton Digital VL1919 19" Monitor
Screen monitor self diagnostics show
that means no incoming signal, but some problem i encountered related in vga cable and lost connection on ckt board. as long that the cpu is working and the monitor show (no signal) focus trouble shooting on that parts. replace cable if possible( same port configuration)
Apr 20, 2010 | Princeton Digital VL2018W Monitor
Princeton VL2018W stopped working. Getting popup "no signal- self diagnostics- check signal cable" When hook up to pc the initial screen showed computer specs than started the popup. Tried changes power...
1. Take this Monitor and attach it to another working computer to see if it works
2. If it works, it means the video card on your pc needs to be replaced
Mar 16, 2010 | Princeton Digital VL2018W Monitor
The monitor shuts off. Turning the power off
the monitor is going into power saving mode ... it can happen if it is not receiving any signal from the pc ( pc is not running or booted properly, bad video cable connection monitor to pc) or the pc is itself in suspend/standby mode.
Aug 08, 2009 | Princeton Digital Computers & Internet
Same problem
Check the Inverter card Connector which goes to pannel,Next Panel to AD card signal Cabble,..
Jul 10, 2009 | Princeton Digital VL1918 Monitor
No display after that
Ok shut it off and take the coords out make sure you re-connect the coords back and try it again.. This should fix it! It tooke me 8 times the other day to get a display so i am hoping it works let me know!
Jun 19, 2008 | Sony Playstation 3 (PS3) Console
Princeton Digital VL1514 Monitor Logo
591 people viewed this question
Top Princeton Digital Computers & Internet Experts
Ekse
Eric Rotmil
Eric Rotmil
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
