Printing from the computer works fine, but when I try to scan or copy documents, a wide vertical grainy black stripe appears down the entire length of the document.
The HP Scanjet IIP scanners are supported in Windows XP and the drivers included on windows XP CD.
If you can’t manage download it from Windows XP operating system please try to update your Operating system then try again.
All the best.
1. Try going to the bottom of any word document.
2. Click on the language tab (will show current language, eg. "German").
3. Select the desired language (eg. "English (U.K.)"). The select the "Default" button (to make it the default language for every future document).
You can also check this link to get detailed information.
Make sure the document lies perfectly straight on the document table.
If you're printing on glossy paper, prints may be scratched if not handled properly. Don't place objects on top of your prints, and be careful not to scratch them with your fingernails. For best results, frame your prints under glass.
A moiré is a cross-hatch pattern that may appear in a scanned image of a printed document. It is caused by interference from the differing pitches in the scanner's screen and the halftone screen in your original.
You can also check this link (manual) to get detailed information.
I hope it helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Sorry for extra information in my previous answer.
I send the it by mistake
Please find yours here..
A moiré is a cross-hatch pattern that may appear in a scanned image of a printed document. It is caused by interference from the differing pitches in the scanner's screen and the halftone screen in your original. Select the Descreening Filter check box in EPSON Scan's Home or Professional Mode window. In Professional Mode, set the Screen Ruling of the Descreening Filter setting to an appropriate setting for your document and deselect the Unsharp Mask Filter setting. See Adjusting the Color and Other Image Settings for instructions.
Select a lower Resolution setting. See Selecting the Scan Resolution for instructions.
All the best.
