I have a Kenmore stacked washer/dryer. I need a new lint filter, but they say it is no longer available. Where can I find one. The model number is 41799175120
Do a part search on Lint filter and you should see the part number 3204278
Although the Sears site says that this part is "no longer available", by doing a Google search on the part number itself, you should be able to find a number of places that have that part.
The lint screen is located on the back wall of the dryer. (Inside of the dryer.) Here's a link to the owner's manual that may be helpful to download and print out: Kenmore 11088752794 Manual
I am not much of an expert with dryers but i'll give it a stab. Should there be a filter that catches the lint so that it does not go all over the clothes? Have you got the manual. If not, see if you can find the manual online and see if there is anything mentioned about a lint filter.
If your dryer isn't drying, check for a simple fix first. Make sure the dryer is set on a high heat setting, empty the lint filter, and reduce the size of the load by taking out some items.
Also, check to make sure the clothes are not dripping when you put them in the dryer and make sure a dryer sheet is not blocking the vent.
It could also be a problem with your dryer not being level or the vent hose is clogged. For more tips and solutions, check out these troubleshooting steps in Dryer not drying.
Get the control panel off and remove the water pressure tubing. Blow it out and reconnect to pressure switch. Remove water so that pressure can once again build inside the tube. Retry>
You must GRARANTEE full and free ari flow outside of the building. Typically this type of complaint is related to restricted air flow outside of the machine...normally there is lots of lint, and it exits through the filter, but when flow is restricted, lint remains inside.
make sure the lint filter is clean, and the duct outlet to the wall is clear. try unplugging the duct from the wall if youa re in an apartment, if it runs cooler , meansi ts clogged in the wall ducts
On your dryer the common problems found is either you lost some of your electrical power (check your fuse box) or you need a new heater #131475300 about $100 for the part.
