Question about Moen & Replacement Cartridge
Removal of moen #1248 cartridge
How does cartridge # 1248 get removed and does it take a special tool ?
Posted by lobster61 on
Robert Smigielskki
    New Friend:
That was exactly the solution I needed for my Jacuzi bath tub with the two handle faucet. The use of the screw in the top of the cartridge was needed to be able to get a strong enough hold on the cartridge stem. Mine is all recessed about 2 1/2 inches so I grabbed the screw head and stem with long nose pliers, and then clamped down on the pliers with a set of adjustable pliers, and then used a 1/2 block of wood as a lever to get pressure on. That got the cartridge to pop out! Thanks!
Posted on Sep 30, 2011
Jyackle5
  • 8,197 Answers
If your faucet is Moen Hi flow roman tub, attach is the removal and installation for 1248 cartridge you need a special tool look at link below.
Attached images removal of moen #1248  cartridge - pdf.gif MT335H.pdf
Posted on Mar 27, 2010
How to replace cartridge on a moen 2 handle faucet 7590
Remove the handle. If the white plastic retainer has a hex nut, remove it with an adjustable wrench. If the retainer has ears, a special Moen two handle cartridge tool is needed. After removing retainer, pull cartridge straight out.
Feb 23, 2018 | Moen Plumbing
Hot water tap leaking what can i do
That is a simple fix - you need to replace the cartridge that is in the faucet handle. however, each manufacturer is different. NOTE sometimes you need a specially designed removal and puller tool. I found this out the hard way. I had a Moen faucet and needed a collar removing tool and a cartridge puller in order to remove the cartridge.
Google
If you need further help, reach me via phone at https://www.6ya.com/expert/michael_e7c2c48c6e65f808
May 01, 2017 | Water Water Heaters
Monticello 1248 cartridge removal
There is an actual tool for the Moen cartridges, not sure on the price but if you contact Moen they can help. As for actual removal , once the handle is removed there is a horseshoe shaped pin that secures the cartridge in place that needs to be removed. If the cartridge has never been removed you will need a bit of elbow grease to pull it out as they tend to stick very well.
Oct 19, 2014 | Plumbing
Remove stem of moen shower cartridge,
Moen makes a stem removal tool that angages the 2 ears on the outer portion of the stem. You can order from Moen:
http://www.moen.com/moen/cartridge-removal-tool-for-1200-or-1225-or-1222-cartridges/_/R-COMMERCIAL%3A104421
Or your local home center or hardware store should have one in stock if they carry Moen parts.
Jan 08, 2012 | Moen Plumbing
Moen Eva two handle lavatory faucet - hot water leak from faucet. Old cartridge removed (had to get a special tool to remove it), new cartridge installed, and leak fixed. Four days later, leak is back...
Hot water side of most faucets give most problems try heating with hairdryer pryor to trying to remove,contact moen tell them of your situation they will more than likely send you a new cartridge free of charge if you raise enough stink about just replacing cartridge.
Jun 08, 2011 | Moen T943/MO4999 Eva Deck Mount Whirlpool...
Moen bathroom faucet leaks from the cartridge. Unable to remove the cartridge. Do I need a special tool?
Usually not a special tool needed. Moen will provide FREE replacements for you, call them up and they will ship to your door, free.
Sep 28, 2010 | Moen & Replacement Cartridge
Moen single handle shower faucet, contstanly drips
Moen single handle - push pull has a screw beneath the handle cover plate. The Moen single lever handle has an allen wrench screw located under the curve of the handle. Once either one of these screws are removed, the handle should come off easily.
Once the handle is off, the water must be turned off and then you can remove the cartridge. Some cartridges are difficult to remove and may require a special tool. Most new cartridge packages have information on them to explain how to remove the cartridge.
Mar 12, 2009 | Home
Moen Castleby T6988 Roman Tub Faucet
with screw removed (the missing one), handle should lift straight up. may need to rock the handle while lifting.
Feb 12, 2009 | Moen Castleby Two-Handle Widespread Roman...
After consulting with Moen re: 2 knob Tub "cartridge" replacement, 12 yrs old, cold water not running, I did what I was told, after receiving the replacement cartridge 1248. (warranty replacement) The...
If the water is off but still coming through, open a tap or two on one of the lower levels.
Basically the old stem does come out thru the top of the valve. Hopefully Moen sent you the tool to do this job. The tool is a 3/4"diameter about 4 inches long. Even on one end and two little tabs on the other.
Take the handle off stem. Remove the upper retaining nut, usually chrome. Pull out the two plastic upper stem pieces. Insert the 2 tabbed end into the stem area. You will feel the tab drop into the retainer ring. Slowly rotate the retainer ring out Counterclockwise. After the retainer ring is out then put the long screw in the stem and pull it out. Sometimes a little leverage helps here.
You will have TWO retainer nuts. The first one is easy just under the handle, the second will require the special insert tool.
Please rate this response and good luck, Phil
Dec 29, 2008 | Moen & Replacement Cartridge
Moen & Replacement Cartridge  Logo
10,036 people viewed this question
Top Moen Home Experts
Mike
john h
Bruce Robin
Are you a Moen Home Expert? Answer questions, earn points and help others
