Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
Tipped over my blender, broke the black plastic piece that raises and lowers the top, and now it is stuck in lower position. Won't move.
Posted by dcdunlap on
Bob Hewitt
  • 130 Answers
Blender? This is a form about Kitchenaid mixers . . . assuming that's what you have,and it is a stand type mixer, look at this page:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
And you will see the linkage which was bent/broken. Hopefully you will be able to either straighten the bent part or replace it if it is broken.
Posted on Mar 30, 2010
How do you tilt the back up on the k45 kitchen stand mixer?
To raise the head you move the locking lever back & lift the front of the motor unit up. To lower it you also move the locking lever to the back and then lower the head and release or push the locking lever forward to lock the head down while using it.
Mar 16, 2015 | Food Mixers
The top part of my mixer is sitting about 1/4 inch lower than it should. It's placing the beater too low in the bowl and therefore won't mix. (I tried to whip up some whipping cream but it pushes...
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download the following Kitchenaid Service Manual:
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
It covers several models including yours.
1. Check/Adjust the Flat Beater to Bowl Clearance:
Turn screw (A) SLIGHTLY counter clockwise (left) to raise the flat
beater or clockwise (right) to lower the flat beater
2. Check the Beater Shaft (Agitator Shaft) making sure the Retaining ring
is flushed with the surface of the Planetary Assembly
Constant Pulling and Removal of the beaters can cause the Agitator shaft to move
3. If the above two still don't solve your problem, follow the service manual
directions to disassemble the Planetary Assembly and check for loose screws
Jul 04, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Mixer head is loose beater scrapes bottom of bowl makes loud thumping noise
I assume you mean that the top half of the mixer, above the pivot pin, moves with respect to the lower half of the mixer, the stand part. There is a pin on which the top half pivots which becomes loose.
Turn the mixer over and look up where the pin goes through the two pieces. There is a screw there which secures the pin. Tap the pin into position and tighten the screw.
Apr 10, 2010 | KitchenAid Artisan Series Tilt-Head Stand...
The black plastic piece that makes our blender spin broke. How can I get it repaired?
Yes, it is very easy to fix. You will need a new coupler, which is part number 9704230. There is a set of instructions with video here: http://www.kaparts.co.uk/Howtoremoveablendercoupler/tabid/219/Default.aspx
Feb 06, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
The handle on my h600 that raises and lowers the bowl broke off. Where can I find a new one?
call hobart, give them the info off the name plate and they will mail you one.
Jul 19, 2009 | Hobart Food Mixers
Plastic piece that raises and lowers the bowl
planetary is the mixining action which was started by kenwood on there mixers in the 50s
Dec 14, 2008 | KitchenAid KP2671 Professional 6 Series...
Broken blender attachment
Wolfgang Puck Housewares Customer Service
800-275-8273
Monday - Friday
9:00 am - 4:30 pm Eastern Time
I would call the number above they should be able to help you out.
Aug 04, 2008 | Wolfgang Puck Stand Mixer
Motor housing cap
I found out from a Waring rep that the motor housing includes the upper and lower units. The company I ordered the housing from didn't include the upper unit. Waring's solution was to return the lower housings and re-order the housing unit from a better company. I haven't heard from the company I ordered it from yet although I've sent them several e-mails.
My solution was simple. I cut the lower units so they'd fit as an upper unit to replace the upper unit
Jul 22, 2008 | Waring DMC201 Stand Mixer
Incomplete mixing
You need to raise the bowl just a little less than the thickness of the layer presently being left behind. Too much and the beaters will touch the bowl .
Jan 31, 2007 | Bosch 700 Watts MUM7010 Concept Series...
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
168 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Colin Stickland
Colin Stickland
Lee Hodgson
Lee Hodgson
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
