Question about Dell 922 All-In-One InkJet Printer
My Canon printer does not print
My Canon S200SP printer does not print any more.
Posted by littleredgor on
  • Anonymous May 11, 2010
    Is it not working at all?
Anonymous
  • 428 Answers
It would have helped really had you given us some idea of what happens when you send a document to print; the fact there are many scenarios. However try the procedure below:-
“All lights blinking and printer not responding” is indicative of serious ink cartridge issue. Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
i.                     Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii.                   The Cartridge electronic panel  is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning.  This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Posted on Mar 27, 2010
4 Related Answers
Anonymous
SOURCE: canon s200sp printing problems
I have lost the disc to set up the connection from the computer to the printer. could you please email me the information.
Posted on Feb 15, 2008
Anonymous
  • 132 Answers
SOURCE: my canon s200sp is not responding, what should i do?
  • Right click on your printer and you will see there an option that says Use printer.. the option you will click on is "ONLINE".
  • After doing that, make sure that the printer is online already.
  • Try printing.
Hope this helps!
Posted on Nov 10, 2008
hashchathy
harsha gayan
  • 246 Answers
SOURCE: canon s200sp error 5C00 says
try to reinstall the printer drivers
Posted on Jan 15, 2009
michael_grey
Michael Grey
  • 365 Answers
SOURCE: CANON S200SP = PRINTER NOT RESPONDING, ERROR CODE
It means print head temperature rise error.
Most likely cuased by using non-Canon inks.Remove the head and clean with an ammonia based cleaner.You should see a build up of gunk/Completely dry the head anr return to service.
Posted on Jun 20, 2009
2answers
I lost the CD installer of S200SPx printer?
Canon Canon S200SPX Drivers
Please visit the above link and download the drivers according to the Operating System you have on your PC.
Hope it helps! Good Luck!
CreativeTECH
1helpful
Need printer driver CANON s200spx serial noFBNR02858
Hi please go to this web site : http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/s_series/s200
Exemple : For Windows 7,follow this procedure : 1- Click on the link : Drivers & Software 2- Select Windows 7 dropdown.gif 3- Under the tag Drivers,Click on aomwin110ea23us.exe 4- click on n-wsss_buttons_agree_over.jpg
GOOD LUCK
2helpful
Have S200SP. Can only print one page. the 2nd page is blank. What do i do to fix Thank you. Enjoy life ..... Don
It is require servicing if you can open the cover and apply some lubricant oil on the steel rod it will fix the problem otherwise reinstall the printer driver..
1helpful
CANON S200SP = PRINTER NOT RESPONDING, ERROR CODE 5200. i try all the following instruction on my screen, but not fixed yet. please help. [email protected]
My canon s200sp is not responding, what should i do?
  • Try printing.
Hope this helps!
I just aquired a printer from an oppurtunity shop without the installation software, the printer is a Canon S200SP is it possible to download the information required thank you
Please visit the page : http://software.canon-europe.com/
And select S200 from consumer printers.
You will be able to download drivers and all necessary utilities
regards,
Konstantin
Canon s200sp printing problems
Printing - using the 'copy' mode of the scanner
This suggests the the 'copy' element of the software is not VISTA compatible. In VISTA help in my computer - check out the 'compatibility' options and select an operating system that the copy function did work under
Dell 922 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
