Question about VeriFone TRANZ 380 Transaction System (X2, 256K) (P03600173)
Got a new tranz 380. it won't stay connected .
Got a new tranz 380(credit card processor). it won't stay connected . error message says "lost connection with host". tech guy says my telephone line is optical. needs to be analog. anything I can do or is this thing a boat anchor ?
Haaa--lllp !!! Nancy
Posted by sawcreek on
Bryan Fullerton
  • 661 Answers
Your shop has optical phone lines? lol I never heard of such a thing and I used to work for MCI worldcom.
All you need to do is call up Qwest or your local phone provider and have them put in a standard analogue phone or fax line.
Here it would run you about 20 bucks if you dont get it as a business line. maybe 50 if you tell them it is for a business.
Posted on Mar 27, 2010
What is error code 16
Code 16
Windows could not identify all the resources this device uses. (Code 16)
To specify additional resources for this device, click the Resources tab and fill in the missing settings. Check your hardware documentation to find out what settings to use.Solution button: None
This code means that the device was not fully detected. When a device is not fully detected, all of its resources may not be recorded.
To resolve this error code, click the Resources tab in Device Manager to manually enter the settings. Good luck..
Apr 29, 2010 | VeriFone TRANZ 380 Transaction System (X2,...
How do I reset the password on a Tranz 330 terminal. I have had this unit for a long time and have not used it in awhile so I have forgotten the information and the paperwork is lost. Please help. I'm...
More than likely the password is your Merchant ID # if not more than likely is you would have to purchase a new one, mainly because most of the machines have been updated by frimware or baud rate which may prevent normal usage to credit card companies.
Sep 19, 2009 | VeriFone TRANZ 380 Transaction System (X2,...
How do I change the ribbon on the VeriFone Tranz 380?
Terminal does not have a ribbon. Do you have a printer connected to it?
Jun 29, 2009 | VeriFone TRANZ 380 Transaction System (X2,...
No card for transation
One if not too late. This terminal is out of compliance with running credit cards through. But if your merchant service provider is allowing you to continue then at the main screen just:
Hit 1
Then enter CC # and enter or function.
Then EXP date of the card then function.
Then Address and or ZIP of the billing for the cardholder
then enter and it should process it VIA dial approval line.
Jun 05, 2009 | VeriFone TRANZ 380 Transaction System (X2,...
How do i VOID A SALE?
What is the model of your credit card unit first. Each one has different features or different ways of VOIDING sales.
Apr 02, 2009 | VeriFone TRANZ 380 Transaction System (X2,...
I need to reprogram our Tranz 380 for new payroll company
What you need to do is to call the customer support line from this new company and have them walk you through the process. What the terminal needs is a new load of software. They can walk you through that process and help you if there are any problems with it.
Jan 16, 2009 | VeriFone TRANZ 380 Transaction System (X2,...
"Programming Err 0"
The error message "Programming Err 0" means that the terminal memory has been corrupted. The only way forward is to acknowledge the situation and reload the terminal application.
If you press the [1] and [FUNC/ENTER] key at the same time, oten the message will go away. However, you will have a terminal with no programming in it. You will need to call your processing company and get a new load.
David
Prairie Trail Software, Inc.
Providing applications and hosting solutions for Tranz terminals and web based transactions
Jun 29, 2008 | VeriFone TRANZ 380 Transaction System (X2,...
Print past detailed reports on my Verifone TRANZ 380
There is not a single answer to this question. Why? Because to be able to print yesterday's report depends on if the application that is in the terminal has been designed to allow you to do that. The only way to answer this question is to ask it of the customer support line of your processor. It may be that the only way to get that information is to have them print it out and mail it to you.
Mar 28, 2008 | VeriFone TRANZ 380 Transaction System (X2,...
Televison & Video Logo
317 people viewed this question
Top VeriFone Televison & Video Experts
Marvin
Marvin
Are you a VeriFone Televison and Video Expert? Answer questions, earn points and help others
