Question about Zenith SY1324S 13" TV
Can't pick up all available channels
I have an old 13 inch Zenith model #SY1324S, I have it hooked up to cable but it wont program in all the available channels I tried on auto program and tried entering the one at a time and it wont pick them up
Posted by dyannal on
Joaquin Hernandez
    New Friend:
  • 65 Answers
Well, remember that in USA all olds tv do not can receive signal because the new signal transmitting is in high-definition and old equipment do not receive that kind of signal.
Posted on Mar 27, 2010
I have a RCA LCD TV model no. RLC3708A and when hooking it up when I took it out of box, I got to
I think you are confusing the channel on the tv and the channel of the cable company that is not something that you can pick up with the scan tv, scan tv is good for picking up local channel meaning air channel that we get with a antenna only not the cable chanel
Jun 24, 2012 | RCA Televison & Video
Use to be able to get all channels now can't get any channel past 19
check the menus channel setup and make sure you are in cable mode and not tv mode, put the tv in cable mode and do a channel search.
Jan 23, 2011 | Zenith SY1324S 13" TV
Need to program channels
This is a LCD tv right?U want to hook up free air or pay cable tv.Go in ur tv menu goto setup,go down to CH.press than pick AIR or CABLE.Than just pick one press scan u will get all free air channels or get all ur pay cable channels
May 26, 2010 | Vizio L37 Television
Skips past all channels after 13. CableVision
I don't know the exact step to set it because I don't know you model TV. When you go to menu set channels it should give you the option to choose cable or air. If you pick cable all your channels will be in VHF which is what you want. If you pick air the first 13 channels will be VHF and the rest will be UHF which cable don't work on. After you pick cable then auto program and you should get all your channels.If this helps you and I hope it does give me a vote please.
Mar 04, 2010 | Televison & Video
In auto program only the first 13 channels are found?
sounds like bad tuner try to program manually and see if it will hold memory
Mar 20, 2009 | Zenith Z32X31D 32" TV
New TV won't ''talk to'' old VCR
using the magnovox remote, reprogram the vcr's channels. set it up to use cable not air. when the vcr was unlugged it lost it's channel memory. don't buy new cables, you're getting a picture and sound so that means your rca cables are ok.
Jan 20, 2009 | Sharp Aquos LC-32D40U Television
Zenith tv model #A32B41W
You probably need to get into the Menu > Tuner Setup and set it for "Cable" instead of "Off Air".
Hope that helps...
Geno
Mar 22, 2008 | Zenith B32A24Z 32" TV
Can't get cable channels, only goes up to ch. 13
First check and see if you are on Cable or Ant. It sounds like you are on ant. Change it to cable. If you are on cable then it's you tuner, you need to replace it.
Sep 14, 2007 | Zenith A25A23W 25" TV
I need to program my tv is cable ready
plse help, i have a cable ready tv hooked up to the coax out of the wall directly to tv and only get 1-13 channels??????
Sep 11, 2007 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
184 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
