I have an intertherm electric furnace Mod#901282. it keeps cutting out and does not come on all the time. any suggestions? also is it possible to convert the electric furnace over to gas
Posted by kimbuzymom on
Anonymous
  • 614 Answers
Sounds **** a sequencer problem. As far as converting to gas. I would go with outside package gas unit. Works great and you do not have the noise. James
Posted on Mar 28, 2010
I have an intertherm furnace model number 901282 and it will not heat my house when i turn on the thermostat it starts but just blows out cold air pleases help
The blower should come on after ignition occurs. When the blower comes on first ignition will not be activated as the thermostat signal shows the heat is on. This happens when the blower relay is stuck in the on condition
Nov 21, 2014 | Intertherm Heating & Cooling
Intertherm feh 015ha
either the heat strips, fusible links on elements or sequencers.
Sep 21, 2013 | Intertherm E3EB010H Electric Furnac
I have an intertherm electric furnace. the heat coils heat up then system shuts down
It is possible that high temp limit is shutting you down.make sure your blower is running when t-stat is calling for heat.if notstart at the heat sequencer which cuts the blower on with first bank of heat. it will be dangerous and difficult to troubleshoot this prob without a multimeter and experiance with elect. components
Nov 05, 2011 | Intertherm P3RA-048K Air Conditioner
Wiring heat only thermostat to inter therm central electric furnace had to replace fuze block, limiter, and sequencer thermostat only has one red wire and one white wire
I am trying to install a Honeywell VisionPro 8000 thermostat for my Intertherm Central Electric Furnace but I am having trouble getting to work any suggestions?
Oct 06, 2010 | Heating & Cooling
Intertherm Heat Pump
Some of the old heat pumps made the reversing valve in the heating mode. On your new thermostat the orange wire will need to be on the B terminal. If it was color coded? I hope you made notes of how it was.
Jan 05, 2010 | Heating & Cooling
I have a intertherm furnace and need to know how to tell the proper filter size this is a mobile home
The best thing to do is buy a washable horsehair filter from home depot and cut it to fit. They are green in color and you cut any size you want. They slide in the door of a gas furnace or along each side of the A coil in an electric furnace. That is your best bet. Most of the time the furnaces comes witha washable filter and it is thrown away after afeew times. Rus
Dec 06, 2009 | Refrigerators
Intertherm furnace model MGHA070AAFC-01 cuts on and off
I assume this is a gas furnace? If so its most likely your fan switch. This is set to come on after the "Chill" is gone on the furnace and go off a few moments after the flame cuts off. there are several different kinds but you will find it if you trace the wiring from the fan motor (usually the colored wire red, blue, or yellow and NOT the black or white or brown) goes to it. If the colors are hard to see use a good lite and some alcohol to clean them up some.
Hope this helps and please rate me accordingly Good Luck.
Mar 11, 2009 | Intertherm P3RA-048K Air Conditioner
Smoke coming from furnace
You may have something (paper,dust, etc.) on the electric coils. There may also be a short in the element.
Mar 24, 2008 | Intertherm P3RA-048K Air Conditioner
Elec. intertherm FURNACE
It would help if I knew what type of system you have, lets start with the thermostat. If you disconnect the wires to it, does the heat turn off? I have seen thermostat wires pinched inside the wall, thus bypassing the thermostat controls altogether and it would run constantly. If you send a reply, tell the type. Wall furnace, central unit, heat & cool, gas, electric or heat pump. If you dont know tell me how many wires you have at the thermostat and the colors. You should know this, as you have changed it.
Jan 05, 2008 | Heating & Cooling
Heating & Cooling Logo
349 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
