Brings up e004 after trying to get it to drain or spin out
Hello travistracey,
The error code E04 for bosch nexxt machines indicates a problem occurred during the drain/pump out. Typically what this really means is an obstruction/debris inside the drain pump, specifically the button trap/lint filter insert.
You haven`t mentioned whether you`ve checked the pump or not, so I`ll assume you didn`t. This is how...
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
Bosch E04 Solution:
The error code should be gone when you restart a cycle however, if the error return`s you`ll need to check further for blockages in the drain hose, or the bellows from the tub to the pump.
Hope this help`s. Thank you for visiting "fixya", please take a moment to rate the solution provided here.
Let me know if you require further assistance. Good luck.
macmarkus :)
Hello again,
I forgot to mention one very important tip regarding the E04 error. This can also be manifesting from using the wrong detergent ( or other additive "cleaners" marketed as the next best cleaners )
The front-load machines must be used with low-sudsing hi-efficient detergent, aka "He". If non hi-efficient detergent has been used, run the machine thru a couple of cycles with some "white vinegar" to rinse out any build up of soap and rinse out clothing previously washed in same manner...with wrong detergent.
Again hope this help`s move you forward. Good luck.
macmarkus :)
Macmarkus, you saved me one expensive repair call - thank you. With your detailed instructions, I was able to get my washer back up and running without much delay or mess. Using our wet vac I was able to stay very dry. So back to my loads of laundry I go. Much appreciated, Erin
The solution was really helpful!!! Thanks you saved my $$ to call someone to look what the issue is.
