Depending on the reason for data loss, there are cheaper solutions out there. If it is only a logical data loss, the price can be very low -- see this site: http://htcilabs.com/services/data-recovery-services/
To repair SanDisk flash drive, you can usesoftware from SanDisk service center. This software can use to repair flashdrive (RAW format, used space 0 bytes, free space 0 bytes, damage firmware,update firmware) and can use for backup data.
U3Launchpad (Win XP, Vista, Seven)
U3Launchpad Update (Win Seven)
In order to flash drive data can be saved, select the Format Option "Quick Format". If we do a Quick Format, data can be saved.
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
I suggest you try to Scandisk in another computer to see if you can recover the data.
Here are several data recovery sites and programs that may help to recover data from faulty flash drives :-
http://www.jufsoft.com/badcopy/flash_dri...
http://www.eprovided.com/usb-flash-drive...
http://www.freedownloadscenter.com/Utili...
http://www.softpedia.com/get/System/Back...
If all else fails then you need to format the flash drive to get it working again BUT you will lose your data.
It pays to make several copies of your data. I backup my data on CDs and DVDs - I make 2 copies, if I breake one I have a spare from which I can make a new copy.
Thanks but they the seem to only go after only pictures not data, and in this case I have more data than pictures. Any other way ?
Yes I have take the time to undock the stick properly. I had started the day normally but I believe there was a glich somewhere as the system would not write to stick, while the system saw it would not write to as it said it could not find it and it would not undock. So I removed it unfortunately thats when the problem started.
