Question about Cobra 148 GTL 120-Channels Base CB Radio
I need a wiring diagram for a roadking 56 to a cobra 148 can u help me
Posted by waccawow26 on
JOHN BABA
    Genius:
  • 1,274 Answers
Pin #1-audio-white,2-shield,3-black,4-Sw com,5-transmit-red .....hope this helps..
Posted on Mar 26, 2010
  • JOHN BABA Mar 28, 2010
    correction: pin1.white,pin2.shield,pin3.black,pin4.red,pin5.blue...sorry about the mix-up. ..Hope this helps..
Have a cobra 148 boughtat local market d expect much told it was a fm rig so i have recieve i have a reverse tx key it is uniace mic 4 pin a question of reversing tx pins in mic many thanx martyn
Go to www.cbtricks.com go to radios and schematics then go to C look for Cobra look for 148 then from there get the mike wiring diagram and you should be in business.
Nov 23, 2016 | Cobra Radio Communications
How do i convert my cobra 29 nw mic to a road king 56 mic?
Look closely at the jack for the microphone and you can see the small numbers that are on it. On the Roadking red and shield (bare) go to 1. White 2, Blue 3, black 4 and the yellow in the cable does not connect to anything.
Jul 17, 2014 | Cobra 29 LTD CB Radio
I have a Cobra 148 mounted on the hump in a pickup truck and it works fine. Then I plugged in a old Turner +3 desk microphone and I get bad feedback when it is keyed up and I can also hear my voice thru...
You're most likely getting lots of RF feedback from the metal cab of your truck,combined with the real sensitive nature of the amplified Turner mike.I would put an old original Cobra (coffin mike) handheld mike or a Astatic Roadking 56 (RK56) on it.They are really hard to beat,especially when you have lots of feedback & squealing. I also have a 148GTL (malaysia made) that has a Turner +3 deskmike & it squeals in my truck but not in the house. The 148GTL has given me better service than ANY other radio I've owned.It has 120 channels (freeband) & upper & lower sideband. I think mine is a 5pin Cobra-type plug-in. Try a simpler mike & good luck. Squirrly
Mar 13, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
Need wiring digram for road king 56 to cobra 29 cb
He is actually looking for the Microphone wiring which is a roadKing Mic to the Radio Cobra 29.
Apr 23, 2009 | Magnum DeltaForce CB Radio
Wiring diagram for a road king 56 4 pin mic
4pin roadking 56 wires came off need to know where they go 1 thru 4
Dec 01, 2008 | Magnum DeltaForce CB Radio
Microphone
If the radio receives OK and the TX red LED will not lit up when keying the mic, then it is a mic or mic cord or mic connector problem (or pin configuration). Internally to the mic, there is a switch for keying the PTT. This should be check down to the coiled cord to the connector.
If all of the above checks OK, then you would need to check the TX/RX regulator/switching circuitry.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 08, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
162 people viewed this question
Top Cobra Radio Communications Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
