Question about Canon NP 6035 Copier
How do you replace toner for canon np 6035 copier
  • Anonymous Mar 30, 2010
    Yes. we opened the front cover, pulled out the toner cartridge and poured the toner into the container. Is that correct?
  • yan dikshteyn May 11, 2010
    have you tried opening the front cover it should be a simple swap
    New Friend:
  • 74 Answers
Close but the toner container is replaceable, you do not have to pour any toner in the container. The replacement toner should be the exact same toner bottle, all you have to do is just swap out with the old one.
Posted on Mar 31, 2010
6ya staff
SOURCE:
Set duplexingunit canon NP 6035
codes e002 et e004 canon copier np6035
Jul 24, 2012 | Canon NP 6035 Copier
Canon 6035 keeps telling me to add toner when it is already full...error goes away after i open and close the hopper door..this seems to happen after every 5 or so copies(sorting and stapeling)
How do you know it's full? Did you record the copy count when you put the toner in? The only time the copier will indicate that it needs toner is when the developer unit is empty or if the toner sensor is not in contact with toner, you should hear a very high pitch squeal sound coming from the copier. If you are sure you have toner inside the developer unit then the toner sensor is bad. Does shaking the developer unit back and forth a few times help? Maybe the toner has developed a cave inside where the toner is supposewd to be touching the toner sensor.
Jun 23, 2011 | Canon NP 6035 Copier
E065 canon NP 6030
If I rember correctly, Your transfer roller unit is arching out. I would first clean off the loose toner in the unit & from the seperation unit. You will need to remove the transfer roller unit. If that dos not clear the code you will need to replace the transfer roller unit. Good Luck
Mar 10, 2011 | Canon NP 6035 Copier
The toner expired quikly
replace tha blank lamp
Feb 03, 2011 | Canon NP 6035 Copier
open the front cover, then you will need to slide out the piece the toner goes into, upper right side. Set the toner cartridge on top. You will see a tab to pull toward you, so the toner will drop down into the copier. Push the tab back in. Then push the cartridge toward the back of the copier a little and pull up.
May 15, 2010 | Canon NP 6035 Copier
How to replace the cleaning web in Canon NP 6035 copier?
You must remove the fixing unit and just look how is assemblled and dissass. it or you can call the service
Jan 09, 2010 | Canon NP 6035 Copier
I have a message about the wate toner being full
open the right side of cover & then remove the west toner box
Nov 16, 2009 | Canon NP 6035 Copier
Out of toner
check toner sensor
Jul 08, 2009 | Canon NP 6035 Copier
Faded black and white print out (Canon NP 6035/6028)
Are you getting a E0020 code? If not there is nothing wrong with the hopper. Has the OPC unit been replaced recently? Also, have you looked at the developing unit? Dose the developer Mag. roller have a even coat or brush on it? If not have you cleaned the S-Blade or doctor blade? Also, have you cleaned the optics?
Aug 13, 2008 | Canon NP 6035 Copier
Printing on Canon NP 6035
I check www.usa.canon.com and couldn't find anything that came close to that model number. You should contact them directly. It may require a copier dealer in your area to get one for you.
Jun 26, 2008 | Canon NP 6035 Copier
Canon NP 6035 Copier Logo
124 people viewed this question
Clive
Clive
old marine
old marine
Ekse
