My bought my dryer 9 years ago and I was doing a few loads of laundry and the dryer worked fine. The next day I went to start the dryer and it did not start. I could hear the timer going but that was it. In reading some of the other problems with the Kenmore dryers, it looks like it could be the thermal fuse. Do I need to replace the thermal fuse and the thermostat both? I have a Kenmore Model 110.62912100
Get a meter,unplug the dryer and read out the fuse,pull one of the wires off when you read it out,also when was the last time you cleaned out the dryer?if it's the fuse usually the air isn't moving very well,you need to clean out the duct that the lint filter slides into,vac out the inside of dryer where the motor is and clean out the vent line and make sure the outside vent is clear,if it's a long run from the back of dryer to the outside i use a leaf blower to blow out the vent line,make sure you have 240 coming in at the back of dryer,you could have a blown fuse,if the thermal fuse is good,check the thermostats on the heater box and read out the heater,good luck,if i can help with anything else let me know
SOURCE: Kenmore series 90 electric dryer does not heat and
Make sure the vent is clear.
Does the motor humm when it starts?
If it humms then the motor is bad. Make sure the rollers are not stuck or that the blower has obstructions inside.
http://www.pdxappliance.com
SOURCE: kenmore series 90 electric dryer
The motor of drum is not work . Just check the motor and power feeds to it
Kenmore dryer wasn't coming on replace thermal fuse thermostat and thermalcutoff fuse and it start working again for a few days and it kick the breaker twice and stop getting hot but still run
