Oliveti copier d-copia16W
if i can agree with ur friend that machine might be similar to sf 5316 so you mentioned a code that appeared on display. the question is if that code is F2 and if the old toner cartridge is exactly simslar to the new one you got from sharp, then the solution i tell you is to replace the plug in pin located at the rear side of the cart. above right the set of gears tied with two screws by the same part from the old previous cartridge. then re install the cartrige and switch ON
