I've seen this complaint 5-6 times within the last month. Try this. Remove the top panel by removing the three screws along the back and pushing the panel back and then lifting up. Locate the pressure sensor mounted on the right side of the machine. Check the pressure sensor hose very carefully for splits or cracks caused by chafing on the tub. You really need to look closely, it only takes a tiny pin hole. If damaged, replace hose and make sure the new hose is routed properly, not taped to the tub as some of the new ones have been for some reason.
