Ok, this is a "Brush Height Adjustment" issue. It will probably work great on a hard surface but on carpet the brushes bog. If you've taken the unit apart already...Sorry....do it again. When you do, you'll see a String which allows the brushes to "Float" on different surface heights. Loosen the screw a little and pull a bit more string through. Re Tighten the screw and put it together enough for a test run. Now reset the roomba.To reset the Roomba, power the Roomba on, and press the Spot, and Dock
buttons together for at least 8 seconds. Until it plays a tune. The
clock, and any schedule is erased at this time. Try running the Roomba
with the dust bin removed to see the brushes spin easier.
Second method, is taking off the bottom cover, and removing the
battery. While it's removed, and not plugged into the charger, press
the clean button for at least 20 seconds. This will erase the memory.
Replace battery, and cover. Run the Roomba to see if the brushes start
to spin. You can also remove the brush housing by removing the 4 screws
and reseating it, to see if it was a bad connection, since you have the
bottom cover off.
My robot doesnt send dust to the filter
SOURCE: Roomba keeps saying "Clean Brushes"!!
Have you made sure the brushes aren't clogged with thread and hair, and that the brush bearings are still good?
1) remove the brush guard.
2) remove the brushes
3) remove any hair or debris using the cleaning tool
4) replace the Roombas brush bearings
5) replace brushed and brush guards
If this doesn't work then, try the following:
