Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
The lights which tell you if you are going at the right speed on my Bissell PROHeat Pro-Tech have stopped working. Just wondering if this could be as simple as a bulb or more serious. Also, how do you remove the clear panel at the front for cleaning? Thanks
Posted by emma_bunce on
Anonymous
    New Friend:
  • 20 Answers
The clear view window is unscrewed with a philips screw driver on either side of the nosel opening (top) but make certain the handle is layed back so as to alleviate twisting off the clear view cover. There are six (6) screws that hold the top cover to the base/motor compartment and you must also unscrew the clear plastic viewing window where the smaller spinner is inside so as to gain access to the hoses that go to the wheels that may have been disconnected or twisted internally that may be the cause of the lights not operating properly.
Posted on Apr 29, 2010
Anonymous
    New Friend:
  • 33 Answers
I have this same model and never noticed the lights telling me the "correct speed" learn something new everyday....
the clear plastic hood removes with a few screws connected to the base at the bottom. the top part snaps out. :)
Posted on Mar 30, 2010
How do I use a brissell 7920 proheat carpet cleaner
PDF]ProHeat® Pro-Tech
banksvac.com/.../product_manuals/bissell/Bissell%20ProHeat%20Pro-Te...
USER'S GUIDE. 7920 / 7901 SERIES ... We're glad you purchased a BISSELL ProHeat Pro-Tech heated formula deep .... assembly and operating instructions, safety precautions, as well as ... *SmartTemp heats the cleaning solution for carpet.
Sep 29, 2015 | Vacuums
New replacement pump on Bissell ProHeat Protech not working
Not sure if I have the same model but this is what I found on mine this morning - wire to switch in the handle came off. Un-plug power cord. Unscrew top two screws on upright handle and remove the front cover above the trigger. see if wires are connected. top connector is not used - if you do solution will spray all the time. Good luck!
Jul 09, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Changing the belt on a bissell proheat 9200
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Jun 09, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Hello.....my Bissell pro heat pro tech does not disperse the water....would you know why
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
eytyet
May 21, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
How do I take apart my Bissell 7920 ProHeat Pro-Tech
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Jul 16, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Water and soap coming out wheel area
heatman101
fddf
Apr 10, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell proheat
heatman101
Apr 04, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Fit a pump to Bissell proheat 7920e
heatman101
wtqy
Jan 09, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 Problem
heatman101
fghj
Jan 08, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Need a user manual for a bissell proheat pro-tech 7920
Go to bissell.com type in the model number 7920 then go to user guide and you can print it.
Jan 02, 2009 | Bissell 9200 Upright Vacuum
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
126 people viewed this question
Top Bissell Vacuums Experts
Marvin
Marvin
Mike
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
