IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Install your cloned ink cartridge into the Epson printer.
Go to "Start > Control Panel" on your computer.
Double-click on "Printer."
Right-click on the icon of your Epson printer and choose "Printer Preferences" at the bottom of the dialog box.
Click on the tab entitled "Speed and Progress" and see the Epson printer monitor box.
Check off the box that says "Disable Epson Status Monitor" to turn off the ink monitor.
Click "Save" and close the windows. Your cloned ink cartridges should now work.
Compatible laser & Inkjet cartridge CISS,Bulk Ink,Refills & Photo paper
professional only about toner chip toner cartridge chip
Count, Charge, Report Printing. Download Free 30-day Trial Now.
True solvent Ink Piezo Inkjet print Distributor Wanted, Made in Korea
