Question about Video Cameras
Conversion vhs to dvd
Had jvc camcorder gr-df460 ( vhs tape),uable to convert recordings to dvd,due to the copyright on the tape set by the camcorder.I no longer have the camcorder.Can i use a similar machine to remove the copyright of the tape and allow conversion?
Posted by josephamoah on
Anonymous
    Genius:
  • 1,035 Answers
I can only offer you 1 option for this case.
In converting the VHS video tape to DVD you can use computer. All you need to have is the VHS player with RCA audio video cables. Then a computer that has video capture card or USB capture card. This will take time but you can just transfer all the copyrighted videos to DVD and to computer data (post to internet)
*Needs realtime transfer VHS to Computer with the prefered resolution option.
*Burn to DVD, it will depends on your DVD drive speed.
Posted on Mar 26, 2010
Recorder stops recording from vhs tapes after about a minute
Some VHS tapes have copyright signals embedded in them. Then when the DVD recorder reads the copyright signal it will stop recording due to it thinking there is a copyright violation happening. Try testing with a VHS TAPE of a show you have recorded off the TV and see if it does the same thing .,
2helpful
How Can I Convert Vhs To Dvd With Protected VHS Tapes?
You can get the solution here: http://www.howtodothings.com/electronics/a4015-how-to-convert-vhs-to-dvd.html
Hope it helps.
1helpful
I need a VHS adapter for the JVC Mini DV tapes
not available - the tapes are different widths for a start, and the two formats use different compression techniques. Adapters are available for VHS-C to VHS because the tape width and the recording format are the same.
2answers
I have a JVC DR MV7SU DVD/Video recorder. How do
If your camcorder allows you to connect to a tv or vcr and allows you to record from it to the camcorder via the rca video input, then you should be able to record it that.  The camcorder must have the RCA audio/video inputs on it to be successful.
enov8
How do I copy from JVC GZ-MG365BU Camcorder to a VHS Tape? How do
ditch the VHS recorder. Burn them onto DVD. It's the 21st century.
JVC GR-AX640u VHS-C Eating Tapes
The capten belt slipped from the motor.so remoce the mechanisum and fix with a new one.
2answers
BURN HOME VIDEO TO DVD
Assuming that your camera is not equipped to interface directly with your PC, here are the steps to take to get your videos from VHS to DVD:
- Purchase a video capture device.
A cursory websearch garnered once for $50.00 here:
ADS Tech Video Xpress
http://www.pcmag.com/article2/0,1759,1902901,00.asp
- After setting the device up, use the bundled software to convert the video file into DVD format and then burn to disc, using your favorite burnig software. Be sure that it is burning in the VIDEO_TS/AUDIO_TS format and not just copying the .avi to the DVD.
If you would like for me to elaborate on anyt of these instructions, please don't hesitate to contact me directly at [email protected]. Good luck and, again, let me know if there's anything else I can do. I think you'll be just fine though as this process is fairly straightforward...just time-consuming.
2answers
Digital camcorder to convert VHS tape to PC for DVD burn
You can't with what you've got I hate to be the bearer of bad news, but in order to play tapes in a vcr and run them through a digital camcorder for output to a computer, the camcorder must have s-video or av inputs. Your camera only has s-video or av outputs, used for sending from the camera to the vcr or tv. Also, some cameras have the inputs but don't support analog to digital pass-through (which is what you are describing). With these cameras you input from the vcr and record it to the tape in the camera, and then output it to the computer. Without the inputs, you can't do either one.
Video Cameras Logo
Top Video Cameras Experts
Tony Parsons
Tony Parsons
Tom Chichester
Are you a Video Camera Expert? Answer questions, earn points and help others
