Question about Apacer Memory Computers & Internet
The pen drive is showing tht it is write protected nothing can be deleted or moved from the pen drive there is no write protection switch on the pen drive
Posted by shoaib_ah528 on
Anonymous
  • 213 Answers
O.k. have you tried the same pen drive on another computer?
if no, please try this and see if you get the same result?
if yes, unfortunately you may have to reformat your pen drive.
your data on the drive may also be lost.
sorry sometimes these things happen.
Posted on Mar 26, 2010
My laptop is reading the pen drive, opening and operating all files but i'm not able to transfer any file to pen drive, although i can transfer files from pendrive to desktop. kindly provide the solution...
if there is no security password or write protect switch (this would be a small switch on the side of the pen drive) then it may be your pc not allowing cut and paste transfer. Try right-clicking on the file you wish to move to the pen drive, click "copy" then right click the pen drive icon and click"paste" this would copy the file to the drive instead of moving it. Moving the file is effectively, copying it to the drive and deleting the origional and if the origional has password or other forms of increased security/priority the pc won't allow it to be deleted or moved.
good luck.
Jan 25, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
HOW TO REMOVE WRITE PRTECTED OR AUTORUN.INF FILES
removing write protection in pen drives is impossible..because tht is due to some hardware problemsi and no software can remove writ protection..anyway try this..logon to a linux machine(i prefer ubuntu )
and in terminal route to your drive and type sudo chmod-R 777/media/ and press enter..if one failes to delete files again..then throw away the pendrive.he heh..!!
Jun 15, 2009 | iLO (2 GB) MP3 Player
Remove Write Protection
This seems to be the problem of most of us these days and some of our readers who wanted to know the methods how they can remove the Write Protected error from their USB drives like Pen Drives and memory cards.
What is Write Protected error and why it happens?
In the Write Protected error, we can’t write or copy any data in our flash drives and even can’t format the drive.
There are many reasons that cause this problem, let’s see solutions of them.
Solutions:
• First of all try to locate a small switch (if any, that you may have not noticed) at some place on the drive or memory card reader. This is the prime reason for this error. If there is one, switch it to the other side to turn the protection off.
• Yes I know this problem is also occurring these days without this switch but not to worry. Just download this helpful software form here
http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Low-Level-Format-Tool.shtml
and run it to execute a “low-level format” on the drive. This software is quite handy and may take few attempts to actually remove the error.
• The problem can also be caused by some virus activity so just get it scanned by some updated good anti virus which may solve your problem.
• BUT if none of the methods listed above solves your problem then your pen drive might have gone corrupted, so just get it replaced.
Hope any of the methods listed above solves your problem.
Update 1:
After the low level format, you may need to “Partition the drive“. Dont worry, partitioning a pen drive means allocating it its File System and Cluster Size that was lost after the Low Level Format.
For that:
  1. Run diskmgmt.msc in Run.
  2. In the disk management window, select the pen drive, right click on it and click on Format.
  3. Now choose the File System and Allocation Unit Size and do not check the boxes below.
Click OK and the drive will be reusable after this.
Update 2 (Better Solution):
Follow the steps in this post and just put the value 0 (zero) in step 5.
This will surely solve your problem now.
rate me and vote me..
May 18, 2009 | Kingston 4GB Secure Digital High Capacity...
Removing write protection of USB pen drive
if u format ur pen drive. then use this step
Check out the registry under:
1)click on start button
2)clik on run dialog box
3)type regedit
4) HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
The value 'WriteProtect' should be absent or set to '0' and when you try to format it you have to format it as FAT16
Good Luck!!
Palwinder
Oct 31, 2008 | iLO (2 GB) MP3 Player
How can I delete write-protected files in pen drive
my multi-card (SD) kingston 2 GB is unable to copy , delete and format. It is always say that your multi-card is write-protect. I try to delete some file on it. It is able to delete but i reconnect to my PC,it shows my previous deleting files. why? If you have time , help me please.
Aug 07, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Problem regarding the write protection of pendrive
Some devices have a physical lock switch on the body of the drive itself. It may or may not be labeled as the lock. Switch it to the other position, and the write protection will be removed.
Jun 11, 2008 | Electronics - Others
hi
my problem is my mobail is bolack but i dont have phone cod number please you give me siemensb100 cod number.
thaink you.
May 15, 2008 | Pen Drive IVO MP3 Player
How to remove write protect from pen drive
I OWN A TRANSCEND pen drive of 8gb when i try to copy or format the command it shows is "cannot create,remove the write protected"what shall i do .the pen drive is very new
Jan 12, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Write protection in pen drives
hi,
could you mention the brand of the pen drive.
anyway for deleting the files . try this--> right click the file and click properties. now check you "read only" (ie. dis-select it ) and select file or folder is ready for archive.
now try to delete it.
hope it helps. and after knowing your brand and model of your pen drive more information can be given.
regards
bzoy
Jan 09, 2008 | Electronics - Others
Computers & Internet Logo
121 people viewed this question
Top Apacer Memory Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an Apacer Memory Computer and Internet Expert? Answer questions, earn points and help others
