Question about Bulova Watch
Vextra men's watch
Set day date and month
Posted by Debra Spriggins on
Anonymous
    New Friend:
  • 51 Answers
Pull crown out once this allows you to set one of the functions by turning crown in one particular direction ..then pull out further to set next function by turning crown in one particular direction then push cronw all the way back to case side..if crown is of the screw down type you will have to unscrew it anti clockwise first then pull it out one click remember to screw it back when you finish
Posted on Mar 26, 2010
My cat watch shockmaster s1143 is delayed by 12hrs. the date indicator didnt match for the current day today. pls help.
When you set the time and date, you set it to (example:) 12 noon rather than 12 midnight. Just turn your time back by 12 hours.
May 09, 2014 | Caterpillar MENS SHOCKMASTER WATCH...
Do you have directions for armitron mens pro sport watch 49/1000
Hi robinmsavage,
I will be glad to help you with your concern regarding your Armitron Wristwatch, what exactly would you be experiencing? cause I only put info on how to set time and date on the Watch.
Please see below steps:
  • Your Armitron Watch will have Four Button on the side of the watches rim.
  • Button on the upper Left is MODE.
  • Button on the lower Left is LIGHT.
  • Button on the upper right is DATE.
  • Button on the lower right is Alarm.
See Steps below:
*Setting the time*
  • Press and Hold down the Mode Button til the Hours flash
  • Then push Alarm Button to set the Hours
  • Press and Hold down the Date Button till the Minutes flash, then push Alarm Button to set the minutes
  • After setting the minutes on your watch, Press Date till you get the month flashing push Alarm to set the month
  • Press the Date again till the Date flashes, then push Alarm to set date
  • Press the Date again till the Date on your watch flashes, then push Alarm to set the date
  • After setting everything push the Mode Button again just once to set everything or finalize your settings on the watch.
I hope that this will be of help regarding your query on how to set the time on your Armitron watch, I also included the setting of the time and date just for further details.
Thank you for choosing Fixya,
mvincentc
Apr 21, 2011 | Armitron Chronograph Sport #204345BKBK...
How do you set the day and month?
Mcdevito75 here, The stem on your Timex shou;ld have two (2) positions, slip a finger nail just under the crown and gently lift to the first position, it may take a little practice to get but you will. In this first position you"ll see by turning the crown one way you can change the date (number) and turning in the other direction you can change the month or day, if so, set the day and date to one (1) day before the day and date you want. Push the stem back in and lift the stem all the way to set the time of day, now cycle thru the watches 24 hours to set the day and date you want. Your Timex is now set and will change at the proper time of around midnite. If your Timex has the month and day you may have to cycle the 24 hours to reach the correct month other than that these instructions should help.
Aug 09, 2010 | Timex T21553 Watch for Men
I have a men's Timex Indiglo watch with day and day of month. It has only i stem. How can I set the date correctly? Lois
Your question brought a smile to my face as I had one also and had the same problem. It took me hours to finally figure out that the stem pulls out to set one thing and pulls out just a little more to set the next.
Hope this helps,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
Mar 10, 2010 | Timex Indiglo Watch
How can I recieve a manual for my Gevril Chelsea?
hi i have a Gevril automatic watch and it said in the manual never try setting the watch between 21:00 - 04:00 , that would damage the internal parts
Nov 25, 2009 | Gevril 18K Chelsea Swiss Automatic...
How do I set the date on an old bulova caravelle men's watch
Pull the stem out 2 clicks the in 1 click turn stem clockwise for day and counter-clockwise for month. to set time pull stem out again 1 click, when finish push in 2 clicks
Jul 09, 2009 | Bulova Watch
How to reset date on skagen watch, model 180LSLW
the stem pulls out three different heights, one is month, one is day, the other is time
May 15, 2009 | Skagen Men's - PERFORMANCE MULTIFUNCTION...
Setting the time, day, date, ona Festina 16059/4 mens watch
Alhamdulillah, the problem solved (at last) tks to IRONMAN (http://www.fixya.com/support/t579677-instructions_mens_festina_watch_16095#SameProblemContinued)
The steps are like this :
1. Pull the crown full, and turn it clockwise until you find the right day.
2. and then push it one click (dont push it to hard so it back to normal position) and turn the crown counter clockwise to adjust date.
3. Push the small button near the crown to adjust month.
and voila... the problem solved
Mar 13, 2009 | Festina 16183 1 Watch
Getting date on watch
udjust the date until the last date of month and surely the month will chagne thank you !
Aug 12, 2008 | Bulova Watch
Change day
The trick is to turn the ring to the "Date" setting, Pull the stem out once for the Month and Date. Pull the stem out (hard, but gently) a second time for the Day of the week. Each pull will be confirmed by a 'beep. Be persistent and good luck.
Oct 15, 2007 | Timex Men's Black Reef Gear i-Control...
Bulova Watch Logo
242 people viewed this question
Top Bulova Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Anthony Ward
Anthony Ward
Are you a Bulova Watch Expert? Answer questions, earn points and help others
