2000 Ford Econoline Logo
Posted on Mar 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi. I need to know which engine oil to use in a ford econoline 250 1997 model please
Wayne Fellows
Level 2:
  • Ford Expert 262 Answers
  • Posted on Mar 26, 2010
Wayne Fellows
Ford Expert
Level 2:
Answers
262
Questions
Helped
246074
Points
802
Engine Oil
XO-10W30-QSP or -DSP ESE-M2C153-E
Here you go. For FREE!!
Anonymous
Level 3:
  • Master 1,297 Answers
Anonymous
Master
Level 3:
Answers
1297
Questions
0
Helped
529300
Points
3746
For gas engines... 5W-20 Premium Synthetic Blend
for diesels...15W-40 or 10W-30 super duty oil
1helpful
I bought a 1983 ford econoline R V last fall , went to start but no luck??? but found oil in the aircleaner what does this mean ,HELP
Oil in the air cleaner usually means a faulty PCV system. Some of the older Ford engines have a filter screen in the rear of the engine block where the PCV hose attaches. The filters get clogged with catbon and must be replaced. This can also cause severe oil leakage from your valve covers because the excessive crankcase pressure will blow out your valve cover gaskets.
The "no start" problem is likely a seperate problem which will have to be diagnosed.
Where is 1989 ford van e150 trans dip stick located?
Most likely you will need to remove the interior engine cover or "dog house" to reach the oil dipstick. Please rate this answer, thanks.
1helpful
What type of oil does a 1995 Ford Econoline E150 Van take??
5W-30 conventional, but full synthetic is a good idea if your engine has no oil leaks.
Where do you add the engine oil?
Hi:
Your Oil Filler Tube And Dip Stick are under your Hood,You'll see a metal Tube around 1 1/2 " diameter,With a Cap.
Hope you find it.
Thanks From: d_hubbs
Where to add oil in a 85 Econoline?
There should be a cap that screws off of one of the two valve covers that you can add oil to the engine through.
1helpful
HOW TO INSTALL SERPENTINE BELT ON 87 FORD VAN
For the 1987 Ford Econoline Van:
Size Engine??
Engine Options (AC/No AC)??
Click on the following direct, Free Link. It has the Serpentine Belt Diagram for your 1987 Ford Econoline Van depending on your size Engine and Engine Options.
Let me know if this helped....
http://www.2carpros.com/car_repair_information/year/1987/make/ford/model/econoline/1987_ford_econoline_drive_belt_routing_diagram.htm
1helpful
I need to know how many wires go to a 1989 ford econoline fuel pump with a 460 efi engine
I suggest check this wiring diagrams for code color wires...
1989 5.0L & 5.8L & 7.5L ENGINE SCHEMATICS
1989-91 CHASSIS (GASOLINE)SCHEMATICS
1989-91 CHASSIS (DIESEL) SCHEMATICS
Hope this help.
Hi we have a 1993 econoline 5ltr will not start
have you changed the spark plugs or cleaned with heat i would change them with new if you can afford it and be 4 putting them in i would crank engine over a few times then take a comparison reading ..if u cant do a reading then i would put several drops of oil in each cylinder put new spark plugs in and try again O when cranking over hold gas pedal all the way down and yes temp sensor can fluid if bad
2helpful
2answers
I dont know where to find the battery and oil filter
If youre looking at the engine, the oil filter is on the right side of the engine, you have to get to it from the bottom of the van. The battery im not too sure off the top of my head, it should be on the right side as well, possibly tucked away in the back corner.
1helpful
3answers
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
