Question about Mitsubishi WS-55511 55" Rear Projection Television
I have the mits ws-55511. had a convergency issue so i changed the stk and a couple resisters and now it doesnt turn on
Posted by idahospud_1 on
electroman
    Genius:
  • Mitsubishi Master
  • 1,039 Answers
Check ics for shorts on the pins. if ok you have a bad ic.
Posted on Mar 26, 2010
How to reset convergence? on mitsubishi ws 55511, has a shadow colored blue or yellow
There is an option in the user menu on the tv. Using either the remote or control panel on the front of the tv, press MENU then select SETUP. After you choose SETUP go to the 3rd column with the 3 icons. Here you can adjust the red or blue color or reset the convergence back to factory default.
After a few years the set will begin to show increasing problems with the convergence settings. When you can no longer adjust either red or blue horizontally or vertically an IC replacement will be needed. Your set uses (1) SANYO stk393-110 and you want to make sure it's SANYO and not a knock off brand as those usually fail prematurely.
Jan 23, 2010 | Mitsubishi WS-55511 55" Rear Projection...
I can't get the convergence on my ws 55511 hdtv to go away. I've tried with the remote. How can I get this corrected?
If the convergence will not adjust you have a convergence circuit problem.
This model uses a single STK-393-110 CONVERGENCE IC 129b244.jpg If you are handy and know how to solder it is a 12 dollar part on EBAY
I have start to finish step by step instructions for this repair in this set.
Most shops will charge 300 or more for this repair.
If you want the instructions let me know and I will post them here for free.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 16, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Ws-55511 red color will not converge, got part
Remove the three screws from the main chassis than release up the two chassis lock on the right and left hand side than slide out you might have to move the DM module on the left side to get the chassis out.
Nov 09, 2009 | Mitsubishi WS-55511 55" Rear Projection...
WS-55511 shuts off with in 1 secound when turned on.
See my reply to your last posting---The set needs The Stk-393-110 and whichever of the two pico fuses is blown replaced--I have instructions AND photos of what the fuses look like.
SD TECH
Sep 15, 2009 | Mitsubishi WS-55511 55" Rear Projection...
From the moment the tv is turned on the horizontal lines appear.It seems to get slightly better as the tv warms up and once in awhile it actually clears up for just a minute or two,then goes back to the...
with the original Mitsubishi remote go into the customer menu and to the Convergence; there will be instructions on screen telling you what to do; if either color does not adjust---you have a bad convergence Ic; the WS-55511 uses a single convergence IC-----it is a STK-393-110; I have seen a lot of them bad and intermittantly bad---someone needs to replace and then take the set into the Technical menu and adjust the convergence there(it is accessed with the remote by entering a number code for this model--any tech should know and be able to fix this problem in your home----I do a lot of these sets with this exact problem. Hope this was helpful.
Aug 11, 2009 | Mitsubishi WS-55511 55" Rear Projection...
My mitsubish model ws-55511 has colors like im watching a 3-d movie. can anyone give me some help
You have a failure in you Convergence circuit.
Probably a pair of STK-392-570's or a single STK393-110. These are common failures with this model series. I do however stress that the location of screws securing the board to the tray poses trouble getting the board out. I do recommend that a qualified serviceman do the job. You do not want to break the board because it probably is not available anymore through Mitsubishi.
I hope this helps,
skyassoc
Jun 22, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Ws 55511 convergence lines bowed down at bottom of screen
Check resistors might have cold solder joints are changed resistance values around replaced STK393-110
Pay attention to faded colored or fried resistors.
You can download service manual for WS-55511 from HERE to get schematics and technical info. (download all 3 parts of file and use WinRAR to extract file)
Good luck.
Dec 13, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mits 55908 Convergence problem
Good Day, John;
It sounds like the Convergence IC's have poor solder connections, by re-soldering the convergence output IC's should solve your problem. The IC's are large and mounted to large silver "heat sink" with STK 392 # on them. Good Luck, big IRISH.
Aug 29, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi television
!-800-553-7278 Mits parts line,however,could we go over the symptoms before you order an expensive part??? Then I will
be able to direct you.....T.
Oct 20, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
105 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
