Replaced bulb in kdf50e2000 ,got a red lamp light, and tv would not come on . now, after replacing bulb, when power is turned on green light comes on(power) fan engages , 2 seconds later i get a red power light and fan stops
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
I have the same TV and had same problem . Try taking the bulb and assembly out and reinstall , there are some sensors on the assemblies that might not be getting good contact . It fixed mine .
Check Lamp Fan if it stops running when Lamp trys to Light ,Then Lamp will not Power up,or Ballast Board itis what powers Lamp on.
Encompass Parts Distribution 1-800-638-3328
Your lamp door switch or lamp switch (there are 2) may not be fully engaged or one may have failed. Try seating the lamp again, you may not have it fully installed.
Hello! Lamp or ballast(if lamp has been replaced) is bad. Explanation: green comes on: system works, waiting for light to shine into light engine: no light is coming out of lamp, system shuts down, then you see red! how to determine: pull the lamp out of the unit's compartment. Inspect lamp: bloated stem? shuttered? reflector is not shiny? Chuck it! Lamp looks good or just been replaced: try ballast. Close lamp compartment without lamp itself. Make sure, door is shut, as well. Turn unit on and listen close to lamp compartment: good ballast will make a buzzing noise, then stop. You've got "red'! No buzzing: ballast quit. Needs major repair! Lamp must be good, for sure, to get to the last part of diagnostics. Conclusion: more, than 2000 hours of usage: replace lamp first! Good luck, Alex.
Hi, Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number... A1085447A* LAMP BLOCK ASSY XL-2200U It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
