Question about Ultra Linear UL801 Car Amp
Amp need to know what kind of fuse to put in a amp 800 watts
Posted by kolaidsmile2 on
Anonymous
    New Friend:
  • 52 Answers
You want to put a 30A into the amp and the inline fuse that you put onto the wire should be greater than 30A but not too high for what the wire is rated. The best bet for wire is to buy a wiring kit which comes with fuse holder, right size fuse, wire for main power ground and remote. You may want to double check what is written on amp for the size to put in there. Technically you can put a 100A onto the wire if it is big enough and the fuse on amp will protect the amp from problems. Hope this helps, Good Luck
Posted on Mar 25, 2010
What thermal fuse do i need for an 800 watt 10amp food dehdrater? heater quit working.
An 800 watt appliance consumes just over three amps with maybe a surge on switch-on but a thermal fuse isn't primarily rated in amps but in degrees (temperature).
The temperature of the replacement fuse should be identical to the original - usually marked on the body. If the original marking has disappeared you will need to use an educated guess or draw on the experience of an appliance engineer if the appliance specifications aren't available.
Dec 27, 2016 | Cars & Trucks
Given 1hp motor how to compute the exact amount of amphere use in circuit breaker
You're not going to be able to do this with just a known Horse Power.
There are 3 elements to the equation, with any two, you can work out the third.
If you want to know how the amperage, you will need to know the voltage and wattage of the motor. I imagine that you already know the voltage (It's going to be 220V or 110 volt)
Watts divided by volts = Amps
Examples:
A 220v 1000 watt motor (1000 divided by 220) will draw 4.55 amps
A 110v 800 watt motor (800 divided by 110) will draw 7.27 amps
Bear in mind that most washing machines have a couple of windings for wash and spin. As an average, the was winding will usually be about 500 watts to spin and about 250 watts to wash. ALSO, bear in mind that if you are using this data for a WASHING MACHINE, then there is a water heating element in there too and that draws about 2Kw (2000 watts)
Dont just take this as read, you DO need to check wattages, but, working on what I have just said, the max consumption on a 220V machine will look like this:
At Spin, with a 500 Watt consumption: (500/220) = 2.3 amps
While Washing with a 250 watt consumption: (250/220) = 1.14 amps
Consider that the WASH and HEAT may be running at the same time.
2Kw heating (2000/220) = 9.1 amps PLUS 1.14 amps for the motor - Total wattage 10.24 amps
Watts / Volts = Amps
Amps x Volts = Watts
Watts divided by amps = Volts
Aug 25, 2011 | Washing Machines
I have a 800 watt inverter an i use a 1500 watt kettle the inverter 15 amp fuse blew
The kettle is 1500 watt 800watt inverter is not big enough you'll blow fuse every time
May 25, 2011 | Inverter 1000-2000w Peak Surge Power
My beringer europowered 800w mixer blew a fuse ,replaced it ,has blown several more fuse's since,i used a lower 5 amp fuse did not last - 10 amp is standard > is it time to trash this unit?
I don't understand because the Xenyx 1002fx draws only 16 Watts so the fuse should be well less than 1 amp why would you put a 5 amp?
And your 800 Watt mixer???... There is something wrong with this model number as the 1002fx certainly is not 800 Watts. Please supply the correct model numbers so we can help you.
The unit is repairable I am sure.
Aug 21, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Toxic tx 600 amplifier
You need to get another amp for your sub. I would say if you want good quality go for MTX because I have had amps from MTX and never had a problem. what you need to know is look at the fuses on the amp if there are 3 of the 25 amp fuses on there then it should push out about 750 watts but on MTX they under clock the amp so it will push about 800 at 14.4 volts for that you will need a 4 gauge wiring kit with a 60 amp fuse in the fuse link. As far as your other amp hook up the speakers and tweeters to that but be sure to tune in down and you would need a 8 gauge wiring kit. I hope this helps you.
Jul 27, 2010 | Car Audio & Video
What kind of amp
It depends on the box you are installing them in. If you're going for sealed box they you can put 600-800 watts on them as long as you're careful with the gains and bass boost off. In a ported enclosure I wouldn't put more than 600 rms on them and still be careful with the gains. set your filter on your amp to about 80 hertz and match it on your source unit.
May 31, 2010 | Kicker CompVR 05CVR84 Car Subwoofer
What Kind Of Car Amplifier Do I Need?
A kicker amp with full range out put that has a switch for the range you most like. do not go over 400 watts rms or the tweeters will blow.
Jul 24, 2009 | Car Audio & Video
I need to know what kind of fuse my amp takes...
IT MAY MEAN THAT IT TAKES (2) 25 AMP FUSES
IF YOU HAVE THEM OUT SEE IF IT SAYS WHAT THEY ARE OR OPEN IT UP IT MAY SAY IT ON THE BOARD OR THE FUSE HOLDER OR LOOK @ THE SPECS ON THE AMP SEE WHAT THE TOTAL CURRENT IS YOU CAN ALWAYS START WITH A SMALLER AMPAGE LIKE 10 -20 AMP FUSE ALWAYS GO SMALLER
Feb 15, 2009 | Sony GR-6.1m Gravity Mono Channel MOSFET...
My 800 watt kenwood
Sounds like you shorted out the main power wire somewhere and killed the amp. Is the amp on the fuse intact or blown? Do you have 12 volts at the amp? check you connections and see if it helps.
Jun 03, 2008 | Kenwood KAC-7201 Car Audio Amplifier
Help putting code in
hello i have 2 audiofinics adf-272 i dont know what kind of amp to hook up with it which one do u think is best for them a mtx 4051 500 watt class d mono block or a mtx 801d 800 watts
Jan 27, 2008 | Car Audio & Video
Ultra Linear UL801 Car Amp Logo
135 people viewed this question
Top Ultra Linear Car Audio & Video Experts
Marvin
Marvin
Are you an Ultra Linear Car Audio and Video Expert? Answer questions, earn points and help others
